"CLICK ON IMAGES TO EXPAND" I have not posted every engine/head manufactured by Mitsubishi because only the most common were posted to serve our purpose here at MightyRam50.net. As you view this page, please check for possible mistakes that I could have made. Mitsubishi's engine coding is by far a crazy number & lettering system that can be very confusing to everyone. We have tried to organize to our best these codes. Send a PM to Bradmph and be sure to describe the problem in full. MMotors.jpg Further Mitsubishi engine information can be located here http://www.mightyram50.net/vbulletin...rt&redirect=no http://www.mightyram50.net/vbulletin...55&redirect=no Mitsubishi Engine Code Information Aspiration T = Turbo Piston & Cylinders 4 = four cylinder 6 = six cylinder 8 = eight cylinder Fuel Type G = Gas D = Deisel Engine Families - 4 cylinder Gas 4A3 = ? / 600cc to 1.1L 4A9 = ? / 1.3L to 1.5L 4B1 = ? / 2.0L to 2.4L 4G1 = Orion / 1.2L to 1.6L 4G3 = Saturn / 1.2L to 1.8L 4G4 = Neptune / 1.2L to 1.4L 4G5 = Astron / 1.85L to 2.6L 4G6 = Sirius / 1.6L to 2.4L 4G9 = ? / 1.5L to 2.0L KE4 = ? / 997cc to 2.3L Engine Families - 6 cylinder Gas & Diesel KE6 = ? / 1,991cc to 3,520cc 6A1 = 1.2L to 2.0L Gas 6B3 = 3.0L 6G7 = Gas "Cyclone V6" KE6 = Straight 6 Saturn 6 = 2.0L Straight 6 built to replace KE6 Engine Families - Diesel 4D5 = Astron Diesel 4M4 = Astron Replacement 2.8 to 3.2 4N1 = Clean Diesel Numeric Code Descriptions of Litre Sizes 11 = 1.2 litre 12 = 1.4 litre 13 = 1.3 litre 15 = 1.5 litre 16 = 1.2 litre 18 = 1.6 litre 31 = 1.5 litre 32 = 3.6 litre 33 = 4.2 litre 34 = 3.9 litre 35 = 4.6 litre 36 = 2.0 litre 37 = 1.8 litre 54 = 2.3 litre 55 = 2.5 litre 56 = 2.6 litre 61 = 1.6 litre 62 = 1.8 litre 63 = 2.0 litre 64 = 2.4 litre 67 = 1.8 litre 69 = 2.4 litre 72 = 3.0 litre 73 = 2.5 litre 74 = 3.5 litre 91 = 1.5 litre 92 = 1.6 litre 93 = 1.8 litre 94 = 2.0 litre MITSUBISHI HEADS - GAS | |
Mitsubishi 1.2 4G11 4G12.jpg | |
Mitsubishi 1.4 G12B-H mit14_G12B-H.jpg | |
Mitsubishi 1.5 4G15 12v mit15_4G15_12v.jpg | |
Mitsubishi 1.5 4G15B Carb 1985 to 1995 mit15_4G15B_carb_85to95.jpg | |
Mitsubishi 1.6 4G61 DOHC 16v 1989 to 1990 mit16_4G61_DOHC16v_89to90.jpg | |
Mitsubishi 1.8 4G37 roller 1990 to 1994 mit18_4G37_roller_90to94.jpg | |
Mitsubishi 2.0 4G94 SOHC 16v mit18_G94_SOHC16v_93to00.jpg | |
Mitsubishi 2.0 G63B SOHC 8v MCA jet mit20_G63B_SOHC8v_MCAjet.jpg | |
Mitsubishi 2.0 G63B SOHC 8v No MCA jet or Fuel Pump Hole G63B_nonMCA.jpg | |
Mitsubishi 2.0/2.4 4G94 SOHC 16v mit20-24_4G94_SOHC16v.jpg | |
Mitsubishi 2.0/2.4 086cast non-turbo DOHC 16v mit20-24nonturbo_086cast_DOHC.jpg | |
Mitsubishi 2.0 G63x non-turbo DOHC 16v mit20nonturbo_G63x_DOHC16v.jpg | |
Mitsubishi 2.0 G63T turbo DOHC 16v 1995 to 1999 mit20turbo_G63Tgen2_DOHC16v_95-99.jpg | |
Mitsubishi 2.0 G63x DOHC 16v big port mit20turbo_G63x_DOHC16v_bigport.jpg | |
Mitsubishi 2.4 G6Kx DOHC 1994 to 1995 mit24_G6K_DOHC_94to95.jpg | |
Mitsubishi 2.4 G64B SOHC 8v MCAjet no pump hole mit24_G64B_SOHChyd_MCAjet_nopumphole.jpg | |
Mitsubishi 2.4 4G64 SOHC LS Intake 1992 to 1995 mits_sohc16_LS_intake-port_cast-G6K_G6N.jpg | |
Mitsubishi 2.4 4G64 SOHC 16v 7bolt 4G64_SOHC_16v_2.4.jpg | |
Mitsubishi 2.4 4G69 SOHC 16v 7bolt 2004 to 2008 4G6916v7bolt.jpg | |
Mitsubishi 2.6 4G54 SOHC Turbo Adjust Rockers 2.6Turbo_adjustable.jpg | |
Mitsubishi 2.6 4G54 SOHC Hemi short cam mit26_4G54_SOHC_shortcam.jpg | |
Mitsubishi 2.6 4G54 SOHC MCA Hemi 4G54MCA.jpg | |
Mitsubishi 2.8 4M40 4M40.jpg | |
Mitsubishi 3.0 6G7S V6 1995 to 2007 mit30_6G7S_95to07.jpg | |
Mitsubishi 3.0 4G6x non-turbo DOHC 12v per head V6 mit30nonturbo_4G6_DOHC12vperhead_V6.jpg | |
Mitsubishi 3.5 G7S4FR/FF SOHC V6 mit35_G7S4FR-FF_SOHC_V6.jpg MITSUBISHI HEADS - DIESEL | |
Mitsubishi 3.3 4D30 Diesel 4D30.jpg | |
Mitsubishi 3.3 4D31 Diesel 4D31_head.jpg | |
Mitsubishi 3.6 4D32 Diesel 4D32.jpg | |
Mitsubishi 4.2 4D33 Diesel 4D33.jpg | |
Mitsubishi 3.9 4D34 Diesel 4D34.jpg | |
Mitsubishi 4.6 4D35 Diesel 4D35.jpg | |
Mitsubishi 3.6 4D36 Diesel 4D36.jpg | |
Mitsubishi 2.3 4D55 Diesel 4D55.jpg | |
Mitsubishi 2.5 4D56T Diesel 4D56T.jpg (4D65, 4D68 - not shown) | |
Mitsubishi 7.5 6D16 Diesel 6D16.jpg |
Created by Last edited by , 12-12-2016 at 09:01 PM 0 Comments, 24,800 Views |
, 05-02-2014 at 06:29 AM
