Engine:Mitsubishi Engines & Heads
"CLICK ON IMAGES TO EXPAND"
I have not posted every engine/head manufactured by Mitsubishi because only
the most common were posted to serve our purpose here at MightyRam50.net.
As you view this page, please check for possible mistakes that I could have made.
Mitsubishi's engine coding is by far a crazy number & lettering system that can be
very confusing to everyone. We have tried to organize to our best these codes.
Send a PM to Bradmph and be sure to describe the problem in full.
Further Mitsubishi engine information can be located here
http://www.mightyram50.net/vbulletin...rt&redirect=no
http://www.mightyram50.net/vbulletin...55&redirect=no
Mitsubishi Engine Code Information
Aspiration
T = Turbo
Piston & Cylinders
4 = four cylinder
6 = six cylinder
8 = eight cylinder
Fuel Type
G = Gas
D = Deisel
Engine Families - 4 cylinder Gas
4A3 = ? / 600cc to 1.1L
4A9 = ? / 1.3L to 1.5L
4B1 = ? / 2.0L to 2.4L
4G1 = Orion / 1.2L to 1.6L
4G3 = Saturn / 1.2L to 1.8L
4G4 = Neptune / 1.2L to 1.4L
4G5 = Astron / 1.85L to 2.6L
4G6 = Sirius / 1.6L to 2.4L
4G9 = ? / 1.5L to 2.0L
KE4 = ? / 997cc to 2.3L
Engine Families - 6 cylinder Gas & Diesel
KE6 = ? / 1,991cc to 3,520cc
6A1 = 1.2L to 2.0L Gas
6B3 = 3.0L
6G7 = Gas "Cyclone V6"
KE6 = Straight 6
Saturn 6 = 2.0L Straight 6 built to replace KE6
Engine Families - Diesel
4D5 = Astron Diesel
4M4 = Astron Replacement 2.8 to 3.2
4N1 = Clean Diesel
Numeric Code Descriptions of Litre Sizes
11 = 1.2 litre
12 = 1.4 litre
13 = 1.3 litre
15 = 1.5 litre
16 = 1.2 litre
18 = 1.6 litre
31 = 1.5 litre
32 = 3.6 litre
33 = 4.2 litre
34 = 3.9 litre
35 = 4.6 litre
36 = 2.0 litre
37 = 1.8 litre
54 = 2.3 litre
55 = 2.5 litre
56 = 2.6 litre
61 = 1.6 litre
62 = 1.8 litre
63 = 2.0 litre
64 = 2.4 litre
67 = 1.8 litre
69 = 2.4 litre
72 = 3.0 litre
73 = 2.5 litre
74 = 3.5 litre
91 = 1.5 litre
92 = 1.6 litre
93 = 1.8 litre
94 = 2.0 litre
MITSUBISHI HEADS - GAS
Mitsubishi 1.2 4G11
Mitsubishi 1.4 G12B-H
Mitsubishi 1.5 4G15 12v
Mitsubishi 1.5 4G15B Carb 1985 to 1995
Mitsubishi 1.6 4G61 DOHC 16v 1989 to 1990
Mitsubishi 1.8 4G37 roller 1990 to 1994
Mitsubishi 2.0 4G94 SOHC 16v
Mitsubishi 2.0 G63B SOHC 8v MCA jet
Mitsubishi 2.0 G63B SOHC 8v No MCA jet or Fuel Pump Hole
Mitsubishi 2.0/2.4 4G94 SOHC 16v
Mitsubishi 2.0/2.4 086cast non-turbo DOHC 16v
Mitsubishi 2.0 G63x non-turbo DOHC 16v
Mitsubishi 2.0 G63T turbo DOHC 16v 1995 to 1999
Mitsubishi 2.0 G63x DOHC 16v big port
Mitsubishi 2.4 G6Kx DOHC 1994 to 1995
Mitsubishi 2.4 G64B SOHC 8v MCAjet no pump hole
Mitsubishi 2.4 4G64 SOHC LS Intake 1992 to 1995
Mitsubishi 2.4 4G64 SOHC 16v 7bolt
Mitsubishi 2.4 4G69 SOHC 16v 7bolt 2004 to 2008
Mitsubishi 2.6 4G54 SOHC Turbo Adjust Rockers
Mitsubishi 2.6 4G54 SOHC Hemi short cam
Mitsubishi 2.6 4G54 SOHC MCA Hemi
Mitsubishi 2.8 4M40
Mitsubishi 3.0 6G7S V6 1995 to 2007
Mitsubishi 3.0 4G6x non-turbo DOHC 12v per head V6
Mitsubishi 3.5 G7S4FR/FF SOHC V6
MITSUBISHI HEADS - DIESEL
Mitsubishi 3.3 4D30 Diesel
Mitsubishi 3.3 4D31 Diesel
Mitsubishi 3.6 4D32 Diesel
Mitsubishi 4.2 4D33 Diesel
Mitsubishi 3.9 4D34 Diesel
Mitsubishi 4.6 4D35 Diesel
Mitsubishi 3.6 4D36 Diesel
Mitsubishi 2.3 4D55 Diesel
Mitsubishi 2.5 4D56T Diesel
(4D65, 4D68 - not shown)
Mitsubishi 7.5 6D16 Diesel
MITSUBISHI MOTORS - Gas
Download a copy of engine comparisons
mitsubishi_engines.zip
4G15 8v SOHC
4G15 12v SOHC
G54B 8v SOHC
4G61 16v DOHC
G62B 8v SOHC
G63B 8v SOHC
4G63 16v DOHC TURBO 7 BOLT SML PORT
4G63 16v DOHC TURBO 6 BOLT
4G64 8v SOHC 6 BOLT
4G64 8v SOHC 6 BOLT 2-Version + 16v SOHC
4G64 16v SOHC 7 BOLT
4G67 16v DOHC
4G69 16v SOHC 7 BOLT
4G93 16v SOHC
6G72 V6
6G73 V6
6G74 V6
6G74 G7S45FR heads V6 3.5 24v
PARTS DIAGRAMS
2.0L SOHC
2.4L SOHC
2.6L SOHC
2.4L DOHC
2.3L SOHC Diesel
This page is Copyright© 2016 - www..MightyRam50.net / www.RacelineCentral.com
Created by , 05-02-2014 at 06:29 AM
0 Comments, 24,467 Views
