Engine:Mitsubishi Engine Reference Code Chart
Mitsubishi Engine Code Reference Chart
As you view this page, please check for possible mistakes that I could have made.
Mitsubishi's engine coding is by far a crazy number & lettering system that can be
very confusing to everyone. We have tried to organize to our best these codes.
Send a PM to Bradmph and be sure to describe the problem in full.
Example: 4G61T (1.6L I4 turbo motor in the Colt/Mirage turbo)
4 = 4-cylinder
G = Gasoline, Iron Block. (D = Diesel ie; 4D65)
6 = Engine Series
1 = Engine Model (Doesn't equate to capacity, as a higher number can belong to a lesser cc'd engine.)
T = Turbo (This is more of an adopted addition to the engine codes, rather than an official part of it. The official way Mitsubishi will list the motor is "4G61 Turbo".)
Example: 6A13TT (2.5L V6 twin-turbo motor in the Galant/Legnum VR-4)
6 = 6-cylinder
A = Gasoline, Aluminum block
1 = Engine Series
3 = Engine Model
TT= Twin-turbo
4 CYLINDER - GxxB & 4G series
G54B - 2.6 SOHC turbo
G62B - 1.85 SOHC turbo
G63B - DASH 2.0 SOHC 12 valve turbo
G63B - 2.0 SOHC turbo
MORE 4 CYLINDER - 4Gxx series
4G11 - 1.2L, 1244cc
4G12 - 1.4L, 1410cc
4G13 - 1.3L, 1248cc
4G15 - 1.5L, 1468cc
4G16 - 1.2L, 1198cc
4G18 - 1.6L, 1583cc
4G30 - 1.3L, 1298cc
4G31 - 1.5L, 1499cc
4G32 - 1.6L, 1597cc
4G33 - 1.4L, 1439cc
4G34 - 1.4L, 1400cc
4G35 - 1.7L, 1686cc
4G36 - 1.2L, 1238cc
4G37 - 1.8L, 1755cc
4G41 - 1.4L, 1378cc
4G42 - 1.2L, 1187cc
4G51 - 1.9L, 1855cc
4G52 - 2.0L, 1995cc
4G53 - 2.4L, 2384cc
4G54 - 2.6L, 2555cc
4G61 - 1.6L, 1597cc. Came available with turbo and naturally aspirated versions. DOHC & SOHC versions were used.
4G62 - 1.8L, 1795cc
4G63 - 2.0L, 1997cc. Came available with turbo and naturally aspirated versions. DOHC & SOHC versions were used.
4G64 - 2.4L, DOHC & SOHC versions were used.
4G67 - 1.8L, 1836cc
4G69 - 2.4L, Motor is a SOHC MIVEC
4G91 - 1.5 DOHC
4G92 - 1.6L, 1597cc. Known commonly for it's DOHC MIVEC version used in the Mirage.
4G93 - 1.8L, 1834cc. Available as a non-turbo SOCH and DOHC. DOHC turbo version was available in '92+ Lancer GSR.
4G94 - 2.0L, Newer SOHC motor used in the Lancer.
MORE 4 CYLINDER - GxxB series
G15B - 1.5L SOHC 12v Carb found in early Mirage and Precis.
G32B - 1.6L. Came as a SOHC turbo.
G54B - 2.6L. Found in early Montero and Truck.
G62B - 1.8L. Came as a SOHC turbo.
G63B - 2.0L. Came as a SOHC sometimes with turbo. Found in JDM Starion as well as the Cordia and Tredia.
G63B - 2.4L. SOHC found on the early Galant and Expo.
4 CYLINER CONTINUED - DIESEL - 4Dxx series
4DQ1 - 1,986cc
4DR1 - 2,384cc
4DR5/6 - 2,659cc
4DR7 - 2,835cc
4D30 - 3,298cc
4D31 - 3,298cc
4D32 - 3,600cc
4D33 - 4,214cc
4D34 - 3,907cc Came available with turbo T4
4D55 - Came available with turbo, 2.3L. Found in Galant 2.3 TD (A167) as well as Pajero (Shogun) 2.3 TD
4D56 - Came available with turbo, 2.5L. Used in Pajero (Shogun) 2.5 TD (L049G)
4D65 - 1.8L. Found in Galant 1.8 TD (E34A)
4D68 - 2.0L, 1998cc
4 CYLINER CONTINUED - DIESEL - 4M4x/5x series
4M40 - 4,899cc came available with turbo
4M41 - came available with turbo
4M42 - came available with turbo
4M50 - 4,899cc Turbo
4M51 - 4,899cc
6 CYLINDER - 6Axx & 6Gxx series
6A10 - 1.6L
6A11 - 1.8L
6A12 - 2.0L. Mostly known to be a DOHC MIVEC used in the FTO. also available in a twin-turbo version in the early 7G Galant VR-4's.
6A13 - 2.5L. Was commonly a DOHC twin-turbo motor used in the more modern 7G and 8G Galant VR-4's.
6G71 - 2.0L, 1998cc. Only known variant is SOHC and supercharged.
6G72 - 3.0L, 2972cc. This motor came in various forms, SOHC and DOHC naturally aspirated versions. DOHC twin-turbo version also available in 3000GT/GTO VR-4.
6G73 - 2.5L, 2497cc. Available naturally aspirated in SOHC and DOHC form.
6G74 - 3.5L. Available naturally aspirated in SOHC and DOHC form.
6G75 - 3.8L. Available naturally aspirated in SOHC and DOHC form.
6 CYLINDER - DIESEL - K series
KE31 - 2,199 cc
Additional Vehicle Engine Information
Mitsubishi 3000 GT (Z16A) 3.0 i 24V 4x4, year 06.92-08.99, engine 6G72
Mitsubishi Carisma (DA_) 1.6, year 07.95-04.96, engine 4G92
Mitsubishi Carisma (DA_) 1.6, year 05.96-06.06, engine 4G92
Mitsubishi Carisma (DA_) 1.6, year 12.98-06.06
Mitsubishi Carisma (DA_) 1.6, year 05.97-06.06, engine 4G92
Mitsubishi Carisma (DA_) 1.6, year 09.00-06.06
Mitsubishi Carisma (DA_) 1.8, year 07.95-04.96, engine 4G93
Mitsubishi Carisma (DA_) 1.8, year 05.96-06.06, engine 4G93
Mitsubishi Carisma (DA_) 1.8 16V, year 07.95-06.06, engine 4G93
Mitsubishi Carisma Sedan (DA_) 1.3, year 09.00-10.04, engine 4G13 (12V)
Mitsubishi Carisma Sedan (DA_) 1.6, year 09.96-06.06, engine 4G92
Mitsubishi Carisma Sedan (DA_) 1.6, year 12.98-06.06
Mitsubishi Carisma Sedan (DA_) 1.6, year 05.97-06.06, engine 4G92
Mitsubishi Carisma Sedan (DA_) 1.6, year 09.00-06.06
Mitsubishi Carisma Sedan (DA_) 1.8, year 09.96-06.06, engine 4G93
Mitsubishi Colt I (A15_A) 1.4 GLX,GT, year 05.79-01.84, engine 4G12
Mitsubishi Colt I (A15_A) 1.4 Turbo, year 09.81-01.84, engine 4G12T
Mitsubishi Colt II (C1_A) 1.2 EL,GL, year 02.84-09.86, engine 4G16
Mitsubishi Colt II (C1_A) 1.2 EL,GL, year 09.86-04.88, engine 4G16
Mitsubishi Colt II (C1_A) 1.3 EL,GL, year 06.86-04.88, engine G13B
Mitsubishi Colt II (C1_A) 1.5 GLX, year 09.85-04.88, engine G15B
Mitsubishi Colt II (C1_A) 1.5 GLX, year 09.84-04.88, engine 4 G 15
Mitsubishi Colt II (C1_A) 1.6 Turbo Eci, year 02.84-04.88, engine 4G32 T/C
Mitsubishi Colt III (C5_A) 1.3, year 04.88-05.92
Mitsubishi Colt III (C5_A) 1.3 12V, year 04.88-05.92, engine 4G13 (12V)
Mitsubishi Colt III (C5_A) 1.3 GL, year 04.88-12.90, engine 4G13
Mitsubishi Colt III (C5_A) 1.5 cat, year 07.90-05.92, engine 4G15
Mitsubishi Colt III (C5_A) 1.5 GLXi, year 04.88-05.92, engine 4G15
Mitsubishi Colt III (C5_A) 1.6 GTi 16V, year 04.88-05.90, engine 4G61
Mitsubishi Colt III (C5_A) 1.8 GTi 16V cat, year 06.90-05.92, engine 4G67
Mitsubishi Colt IV (CA_A) 1.3 GLi 12V, year 04.92-04.96, engine 4G13
Mitsubishi Colt IV (CA_A) 1.6, year 02.94-04.96, engine 4G92
Mitsubishi Colt IV (CA_A) 1.6 4x4, year 08.93-08.95, engine 4G92
Mitsubishi Colt IV (CA_A) 1.6 GLXi 16V, year 04.92-04.96, engine 4G92
Mitsubishi Colt IV (CA_A) 1.8 GTi 16V, year 04.92-04.96, engine 4G93
Mitsubishi Colt V (CJ_A) 1.3, year 09.00-07.05, engine 4G13 (16V)
Mitsubishi Colt V (CJ_A) 1.3 GL,GLX, year 05.96-09.00, engine 4G13 (12V)
Mitsubishi Colt V (CJ_A) 1.5, year 11.95-07.05, engine 4G15 (16V)
Mitsubishi Colt V (CJ_A) 1.6, year 09.00-07.05
Mitsubishi Colt V (CJ_A) 1.6 GLX, year 05.96-09.00, engine 4G92
Mitsubishi Diamante Sedan 3.0, year 10.92-05.99, engine 6G72
Mitsubishi Eclipse Cabriolet 1.8, year 12.89-03.94, engine 4G37
Mitsubishi Eclipse I (D2_A) 1.8, year 12.89-03.94, engine 4G37
Mitsubishi Eclipse I (D2_A) 2.0 i 16V, year 04.91-11.95, engine 4G63
Mitsubishi Eclipse I (D2_A) 2.0 i 16V 4x4, year 04.91-11.95, engine 4G63
Mitsubishi Eclipse I (D2_A) 2.0 Turbo 4WD, year 12.89-03.94
Mitsubishi Eclipse II (D3_) 2.0 GS 16V, year 12.95-04.99, engine 4G63
Mitsubishi Eclipse II (D3_) 2.0 GT 16V, year 12.95-04.99
Mitsubishi Eclipse II (D3_) 2.0 Turbo 4WD, year 12.95-04.99
Mitsubishi Galant II (A16_) 1.6 GLX, year 09.80-05.84, engine 4G32
Mitsubishi Galant II (A16_) 2.0 GLS, year 09.80-05.84, engine 4G63
Mitsubishi Galant II (A16_) 2.0 Turbo Eci, year 05.82-05.84, engine 4G63T
Mitsubishi Galant II Station Wagon (A16_V) 1.6 GLX, year 09.80-05.84, engine 4G32
Mitsubishi Galant II Station Wagon (A16_V) 2.0 GLX, year 09.80-06.83, engine 4G63
Mitsubishi Galant III (E1_A) 1.6 GLX, year 06.84-12.87, engine 4G32
Mitsubishi Galant III (E1_A) 2.0 GLS, year 06.84-12.87, engine 4G63
Mitsubishi Galant III (E1_A) 2.0 Turbo Eci, year 06.84-05.85, engine 4G63T
Mitsubishi Galant III (E1_A) 2.4 GLS, year 07.85-12.87, engine G64B
Mitsubishi Galant IV (E3_A) 1.8, year 11.88-10.92, engine 4G37
Mitsubishi Galant IV (E3_A) 2.0, year 04.89-10.92, engine 4G63
Mitsubishi Galant IV (E3_A) 2.0 4x4, year 04.89-10.92, engine 4G63
Mitsubishi Galant IV (E3_A) 2.0 GTi 16V, year 11.88-10.92, engine 4G63
Mitsubishi Galant IV (E3_A) 2.0 GTi 16V 4x4, year 07.89-12.92, engine 4G63
Mitsubishi Galant IV Sedan (E3_A) 1.8, year 11.87-08.90, engine 4G37
Mitsubishi Galant IV Sedan (E3_A) 1.8, year 11.87-10.92, engine 4G37
Mitsubishi Galant IV Sedan (E3_A) 2.0, year 11.87-10.92, engine 4G63
Mitsubishi Galant IV Sedan (E3_A) 2.0 4x4, year 12.88-10.92, engine 4G63
Mitsubishi Galant IV Sedan (E3_A) 2.0 GTi 16V, year 11.87-10.92, engine 4G63
Mitsubishi Galant IV Sedan (E3_A) 2.0 GTi 16V, year 11.88-10.92, engine 4G63
Mitsubishi Galant IV Sedan (E3_A) 2.0 GTi 16V 4x4, year 06.88-10.92, engine 4G63
Mitsubishi Galant IV Sedan (E3_A) 2.0 GTi 16V 4x4 cat, year 09.91-10.92, engine 4G63
Mitsubishi Galant V 1.8, year 02.94-08.96, engine 4G93
Mitsubishi Galant V 1.8 GLSI, year 11.92-08.96, engine 4G93
Mitsubishi Galant V 2.0 GLSI, year 11.92-08.96, engine 4G63
Mitsubishi Galant V 2.0 GLSI 4x4, year 11.92-08.96, engine 4G63
Mitsubishi Galant V 2.0 V6 24V, year 11.92-08.96, engine 6A12
Mitsubishi Galant V 2.5, year 11.92-09.96, engine 6G73
Mitsubishi Galant V 2.5 V6 24V 4x4, year 11.92-08.96, engine 6G73
Mitsubishi Galant V Sedan 1.8, year 02.94-08.96, engine 4G93
Mitsubishi Galant V Sedan 1.8 GLSI, year 11.92-08.96, engine 4G93
Mitsubishi Galant V Sedan 2.0 GLSI, year 11.92-08.96, engine 4G63
Mitsubishi Galant V Sedan 2.0 GLSI 4x4, year 11.92-08.96, engine 4G63
Mitsubishi Galant V Sedan 2.0 V6 24V, year 11.92-08.96, engine 6A12
Mitsubishi Galant V Sedan 2.5 V6 24V 4x4, year 11.92-08.96, engine 6G73
Mitsubishi Galant VI (EA_) 2.0, year 09.96-09.00, engine 4G63
Mitsubishi Galant VI (EA_) 2.0, year 09.00-10.04
Mitsubishi Galant VI (EA_) 2.5 V6 24V, year 09.00-10.04, engine 6A13
Mitsubishi Galant VI (EA_) 2.5 V6 24V, year 09.96-09.00, engine 6A13
Mitsubishi Galant VI Station Wagon (EA_) 2.0, year 09.96-09.00, engine 4G63
Mitsubishi Galant VI Station Wagon (EA_) 2.0, year 09.00-10.03
Mitsubishi Galant VI Station Wagon (EA_) 2.5 V6 24V, year 09.00-10.03, engine 6A13
Mitsubishi Galant VI Station Wagon (EA_) 2.5 V6 24V, year 09.96-09.00, engine 6A13
Mitsubishi L 200 (K__T) 2.0, year 11.86-08.96, engine 4G63
Mitsubishi L 200 (K__T) 2.0, year 06.96-, engine 4G63
Mitsubishi L 200 (K__T) 2.0 4x4, year 11.86-05.92, engine 4G63
Mitsubishi L 200 (K__T) 2.4 4x4, year 06.96-, engine 4G64
Mitsubishi L 200 (K__T) 3.0 4x4, year 11.86-05.92
Mitsubishi L 300 Bus 1.8, year 03.83-10.86, engine 4G62
Mitsubishi L 300 Bus 1.8 4x4, year 08.84-02.87, engine 4G62
Mitsubishi L 300 Bus 2.0, year 12.86-, engine 4G63
Mitsubishi L 300 Bus 2.0, year 11.86-, engine 4G63
Mitsubishi L 300 Bus 2.0 4WD, year 11.86-, engine 4G63
Mitsubishi L 300 Bus 2.0 4x4, year 11.86-02.87, engine 4G63
Mitsubishi L 300 Bus 2.4, year 08.88-08.97
Mitsubishi L 300 Bus 2.4, year 11.90-, engine 4G64
Mitsubishi L 300 Bus 2.4 4WD, year 11.86-12.90, engine G64B
Mitsubishi L 300 Bus 2.4 4WD, year 11.90-, engine 4G64
Mitsubishi L 300 Bus 2.4 GLX 4x4, year 11.86-08.97
Mitsubishi L 300 Flatbed/Chassis 2.0, year 07.94-, engine 4G63
Mitsubishi L 300 Van 1.8, year 03.83-10.86, engine 4G62
Mitsubishi L 300 Van 2.4, year 11.86-08.97, engine G64B
Mitsubishi L 300 Van 2.4 4x4, year 11.86-08.97, engine G64B
Mitsubishi Lancer Combi 2.0 16V, year 09.03-12.07, engine 4G63 (DOHC)
Mitsubishi Lancer Combi (CS_W) 1.6, year 09.03-, engine 4G18
Mitsubishi Lancer I (A17_) 1.2, year 01.80-12.81, engine 4G11
Mitsubishi Lancer II (A17_) 1.2 GLX, year 03.83-01.84, engine 4G11
Mitsubishi Lancer III (C1_A, C6_A) 1.2, year 08.86-04.88, engine 4G16
Mitsubishi Lancer III (C1_A, C6_A) 1.2 GL, year 01.84-10.86, engine 4G16
Mitsubishi Lancer III (C1_A, C6_A) 1.5 GLX, year 06.85-04.88, engine G15B
Mitsubishi Lancer III (C1_A, C6_A) 1.5 GLX, year 11.83-04.88, engine 4 G 15
Mitsubishi Lancer III Station Wagon 1.5, year 09.85-08.89, engine G15B
Mitsubishi Lancer III Station Wagon 1.5, year 09.85-12.87, engine 4G15
Mitsubishi Lancer III Station Wagon 1.5, year 09.88-12.90, engine 4G15
Mitsubishi Lancer III Station Wagon 1.5 12V, year 09.90-12.91, engine 4G15
Mitsubishi Lancer III Station Wagon 1.8 4x4, year 03.89-12.90, engine 4G37
Mitsubishi Lancer III Station Wagon 1.8 4x4, year 01.87-12.87, engine 4G37
Mitsubishi Lancer III Station Wagon 1.8 4x4, year 08.90-06.92, engine 4G37
Mitsubishi Lancer IV (C6_A, C7_A) 1.3, year 05.88-06.90, engine G13B
Mitsubishi Lancer IV (C6_A, C7_A) 1.3 12V, year 07.90-07.93, engine 4G13
Mitsubishi Lancer IV (C6_A, C7_A) 1.3 12V, year 06.92-05.94, engine 4G13
Mitsubishi Lancer IV (C6_A, C7_A) 1.5, year 06.88-05.92, engine 4G15
Mitsubishi Lancer IV (C6_A, C7_A) 1.5 12V, year 05.89-05.92, engine 4G15
Mitsubishi Lancer IV (C6_A, C7_A) 1.6 16V, year 06.92-05.94, engine 4G92
Mitsubishi Lancer IV (C6_A, C7_A) 1.6 GTi, year 05.88-05.90, engine 4G61
Mitsubishi Lancer IV (C6_A, C7_A) 1.8 4x4, year 09.89-06.92, engine 4G37
Mitsubishi Lancer IV (C6_A, C7_A) 1.8 GTi 16V, year 11.89-05.92, engine 4G67
T902B - Ignition lead set for 1.8 GTi 16V Lancer IV (C6_A, C7_A) 1.8 GTi 16V
Mitsubishi Lancer IV (C6_A, C7_A) 1.8 GTi 16V, year 06.92-12.93, engine 4G93
Mitsubishi Lancer IV Sedan (C6_A) 1.3, year 04.88-05.92, engine 4G13
Mitsubishi Lancer IV Sedan (C6_A) 1.3, year 08.88-05.92, engine G13B
Mitsubishi Lancer IV Sedan (C6_A) 1.3 12V, year 01.91-06.92, engine 4G13
Mitsubishi Lancer IV Sedan (C6_A) 1.3 GL, year 05.88-06.90, engine G13B
Mitsubishi Lancer IV Sedan (C6_A) 1.5, year 04.88-05.92, engine 4G15
Mitsubishi Lancer IV Sedan (C6_A) 1.5 12V, year 05.89-05.92, engine 4G15
Mitsubishi Lancer IV Sedan (C6_A) 1.6 GTi, year 05.88-05.90, engine 4G61
Mitsubishi Lancer Sedan (CS_A) 1.3, year 09.03-, engine 4G13 (16V)
Mitsubishi Lancer Sedan (CS_A) 1.6, year 09.03-, engine 4G18
Mitsubishi Lancer V (CB/D_A) 1.3, year 06.92-02.95, engine 4 G 13 (12V)
Mitsubishi Lancer V (CB/D_A) 1.3, year 06.92-, engine 4G13 (12V)
Mitsubishi Lancer V (CB/D_A) 1.6, year 02.94-, engine 4G92
Mitsubishi Lancer V (CB/D_A) 1.6 16V, year 06.92-, engine 4G92
Mitsubishi Lancer V (CB/D_A) 1.6 16V 4WD, year 06.92-, engine 4G92
Mitsubishi Lancer V (CB/D_A) 1.8 16V, year 06.92-12.93, engine 4G93
Mitsubishi Lancer V Station Wagon 1.3, year 11.99-08.03, engine 4G13 (12V)
Mitsubishi Lancer V Station Wagon 1.3 16V, year 09.97-10.99, engine 4G13
Mitsubishi Lancer V Station Wagon 1.6 16V, year 12.92-10.03, engine 4G92
Mitsubishi Lancer V Station Wagon 1.6 16V 4WD, year 12.92-10.03, engine 4G92
Mitsubishi Lancer VI 2.0 16V EVO IV-V-VI-VII, year 08.96-08.03, engine 4G63 Turbo
Mitsubishi Lancer VI (CK/P_A) 1.3 12V, year 12.95-08.03, engine 4G13
Mitsubishi Lancer VI (CK/P_A) 1.5 16V, year 12.95-08.03, engine 4G15
Mitsubishi Lancer VI (CK/P_A) 1.6 16V, year 12.95-08.03, engine 4G92
Mitsubishi Mirage 1.5, year 04.86-01.88, engine G31B
Mitsubishi Mirage 1.8 GTi, year 12.91-07.03, engine 4G93
Mitsubishi Mirage Sedan 1.8 GSi, year 12.91-08.95, engine 4G93
Mitsubishi Montero 3.0 V6 24V, year 06.94-05.97, engine 6G72
Mitsubishi Montero 3.5 V6 24V, year 06.94-05.97, engine 6G74 DOHC
Mitsubishi Outlander I 2.0 16V, year 05.03-10.06, engine 4G63 (DOHC)
Mitsubishi Outlander I 2.0 16V 4WD, year 05.03-, engine 4G63 (DOHC)
Mitsubishi Outlander I 2.0 16V 4WD, year 05.03-10.06, engine 4G63 (DOHC)
Mitsubishi Outlander I 2.0 16V Turbo 4WD, year 04.04-, engine 4G63T (DOHC)
Mitsubishi Pajero I (L04_G, L14_G) 3.0 V6, year 11.88-11.90, engine 6G72
Mitsubishi Pajero I Canvas Top (L04_G) 2.6, year 01.83-11.90, engine 4G54
Mitsubishi Pajero II (V2_W, V4_W) 2.4, year 04.91-04.00, engine 4G64
Mitsubishi Pajero II (V2_W, V4_W) 3.0 V6, year 12.90-12.95, engine 6G72
Mitsubishi Pajero II (V2_W, V4_W) 3.0 V6 24V, year 06.97-04.00, engine 6G72
Mitsubishi Pajero II (V2_W, V4_W) 3.0 V6 24V, year 06.94-05.97, engine 6G72
Mitsubishi Pajero II (V2_W, V4_W) 3.5 V6 24V, year 07.97-04.00
Mitsubishi Pajero II (V2_W, V4_W) 3.5 V6 24V, year 06.94-06.97, engine 6G74 (DOHC)
Mitsubishi Pajero II (V25W V45W) 3.5 V6 24W, year 06.97-04.00, engine 6G74 (DOHC)
Mitsubishi Pajero II (V43W, V23W) 3.0 V6 24V, year 06.97-04.00, engine 6G72 (DOHC)- 5mm cables
Mitsubishi Pajero II (V43W, V23W) 3.0 V6 24V, year 06.94-05.97, engine 6G72 (DOHC) - 5 mm cables
Mitsubishi Pajero II Canvas Top 2.4, year 04.91-04.00, engine 4G64
Mitsubishi Pajero II Canvas Top 3.0 V6, year 12.90-12.95, engine 6G72
Mitsubishi Pajero II Canvas Top 3.0 V6 24V, year 06.94-04.00, engine 6G72
Mitsubishi Pajero II Canvas Top (V23W, V23C) 3.0 V6 24V, year 06.94-04.00, engine 6G72 (DOHC) - 5 mm cables
Mitsubishi Pajero III (V60, V70) 3.5 V6 GDI, year 04.00-
Mitsubishi Pajero Pinin (H6_W, H7_W) 1.8, year 11.01-, engine 4G93
Mitsubishi Pajero Pinin (H6_W, H7_W) 1.8 GDI, year 10.99-
Mitsubishi Pajero Sport (K96W) 3.0 V6 24V, year 06.00-, engine 6G72 (DOHC)
Mitsubishi Pajero Sport (K96W) 3.0 V6 24V, year 11.98-, engine 6G72 (DOHC/SOHC)
Mitsubishi Santamo 2.0, year 05.99-
Mitsubishi Sapporo II (A16_A) 2.0 GSR, year 08.80-09.84, engine 4G63
Mitsubishi Sapporo III (E16A) 2.4, year 06.87-08.90, engine 4G64
Mitsubishi Sigma (F16A) 3.0 V6, year 12.90-07.96, engine 6G72
Mitsubishi Sigma Station Wagon (F07W) 3.0, year 01.93-07.96, engine 6G72
Mitsubishi Space Gear (PA/B/D_V/W) 2.0 16V, year 08.96-05.00, engine 4G63
Mitsubishi Space Gear (PA/B/D_V/W) 2.4 i, year 05.95-05.00, engine 4G64
Mitsubishi Space Gear (PA/B/D_V/W) 2.4 i 4x4, year 05.95-05.00, engine 4G64
Mitsubishi Space Runner (N1_W, N2_W) 1.8, year 06.96-08.99, engine 4G93
Mitsubishi Space Runner (N1_W, N2_W) 1.8, year 10.91-08.99, engine 4G93
Mitsubishi Space Runner (N1_W, N2_W) 1.8 4x4, year 06.96-08.99, engine 4G93
Mitsubishi Space Runner (N1_W, N2_W) 1.8 4x4, year 10.91-08.99, engine 4G93
Mitsubishi Space Runner (N50) 2.0, year 08.99-, engine 4G63
Mitsubishi Space Star (DG0) 1.3 16V, year 09.00-, engine 4G13
Mitsubishi Space Star (DG0) 1.3 16V, year 12.98-, engine 4G13
Mitsubishi Space Star (DG0) 1.3 16V, year 06.98-, engine 4G13
Mitsubishi Space Star (DG0) 1.6 16V, year 01.01-, engine 4G18
Mitsubishi Space Star (DG0) 1.8 GDI, year 10.02-, engine 4G93
Mitsubishi Space Star (DG0) 1.8 GDI, year 06.98-
Mitsubishi Space Star (DG0) 1.8 GDI, year 06.98-, engine 4G93
Mitsubishi Space Wagon (D0_V/W) 1.8 4x4, year 10.87-08.88, engine 4G37
Mitsubishi Space Wagon (D0_V/W) 1.8 GLX, year 01.84-12.88, engine 4G37
Mitsubishi Space Wagon (D0_V/W) 2.0 4x4, year 03.85-04.91, engine 4G63
Mitsubishi Space Wagon (D0_V/W) 2.0 GLX, year 06.86-05.88, engine G63B
Mitsubishi Space Wagon (D0_V/W) 2.0 GLX 4x4, year 06.86-05.88, engine G63B
Mitsubishi Space Wagon (D0_V/W) 2.0 GLXi, year 06.88-04.91, engine 4G63
Mitsubishi Space Wagon (D0_V/W) 2.0 GLXi 4x4, year 06.88-04.91, engine 4G63
Mitsubishi Space Wagon (N3_W, N4_W) 1.8, year 10.91-10.98, engine 4G93
Mitsubishi Space Wagon (N3_W, N4_W) 1.8 4x4, year 10.91-10.98, engine 4G93
Mitsubishi Space Wagon (N3_W, N4_W) 2.0, year 10.92-10.98, engine 4G63
Mitsubishi Space Wagon (N3_W, N4_W) 2.0 4x4, year 10.92-10.98, engine 4G63
Mitsubishi Space Wagon (N5_W) 2.4 GDI, year 10.98-, engine 4G64 (GDI)
Mitsubishi Space Wagon (N5_W) 2.4 GDI 4x4, year 10.98-, engine 4G64 (GDI)
Mitsubishi Tredia (A21_) 1.8 GLS, year 08.84-07.86, engine 4G37
Mitsubishi Tredia (A21_) 1.8 Turbo, year 08.84-07.86, engine G62B
Further Mitsubishi engine information located here
http://www.mightyram50.net/vbulletin...55&redirect=no
http://www.mightyram50.net/vbulletin...ines+and+Heads
Created by , 08-17-2014 at 05:36 PM
0 Comments, 37,344 Views
