Wheels & Tires:OEM Wheels & Parts Diagram
This is the OEM wheel listing with CNC numbers & lug patterns
(click image to expand)
MITSUBISHI WHEEL PATTERNS - That match our trucks stock pattern
6 lug 5.5 inch or 139.7mm Medium Offset
Be sure to always check wheel offset, which can be a factor when installing the tires
1983 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1984 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1985 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1986 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1987 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1988 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1989 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1990 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1991 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1992 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1993 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1994 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1995 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1996 Mitsubishi Pickup 6 lug 5.5 inch or 139.7mm Medium Offset
1988 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1989 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1990 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1991 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1992 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1993 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1994 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1995 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1996 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1997 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1998 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1999 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2000 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2001 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2002 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2003 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2004 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2005 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2006 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2007 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
2008 Mitsubishi Montero 6 lug 5.5 inch or 139.7mm Medium Offset
1997 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
1998 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
1999 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
2000 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
2001 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
2002 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
2003 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
2004 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
2005 Mitsubishi Montero Sport 6 lug 5.5 inch or 139.7mm Medium Offset
DODGE Ram50 / D50
1986 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
1987 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
1988 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
1989 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
1990 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
1991 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
1992 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
1993 Dodge D 50 Pickup 6 lug 5.5 inch or 139.7mm Standard Offset
Created by , 07-23-2013 at 08:49 PM
0 Comments, 9,972 Views
