Results 1 to 25 of 26
Thread: Oil Filters for 4D55 the Monsters PH6353/MD069783
    A bigger filter won't extend the oil life. The only thing to do that is Synthetic oil.
    More oil in the system = longer to break down. Running a bigger oil filter will also offer more filtration surface. But it won't have that bigger impact on oil serviceability (it will be a little cleaner at the service interval if anything - it's only increasing volume by a cup/250 ml). If you were going to do something to improve oil life it would be using a remote filter and oil cooler core (I don't know if the remote system really needs a thermostat unless you're in extreme conditions like below zero temps). It's heat that'll break down the oil.
    Seattle,WA
    1991 Mitsubishi Mighty Max
    4D55
    That's not really the point, these filters have a 30 mm thread on the engine mount and 100 mm gasket. One does not have a choice to use a smaller filter, you must use the one that fits!
