Results 1 to 9 of 9
Thread: Starter Bolt size?
    ks
    4G63
    Starter Bolt size?
    Just pulled a 2.6L Power Ram into the shop that's missing the starter and the bolt that would go to it....what size is the bolt? thanks!
    Turtle Island
    Quote Originally Posted by epheme View Post
    There is two starter bolts. I'm not sure the size. If no one has the answer. I'll pull my starter bolts out for you and I'll measure them.
    ks
    4G63
    That would be incredibly helpful thank you. Starter won't be here for a week so hopefully someone knows.
    Turtle Island
    I hope that's what you were looking for. Any questions, ask away. 14mm bolt head btw.
    Seattle, WA
    The first post of this thread has a diagram of the trans mounting points and bolts.
    http://www.mightyram50.net/vbulletin...is-help-please
    The starter mounts using two Item C or one C and one B (bolts). The diagram isn't that clear. I believe the pitch is 1.25. Should be the same as the other 10mm bellhousing bolts, so you could use one of them to verify.
    FMS88 is correct
    Look at claych's post on this thread http://www.mightyram50.net/vbulletin...-motor-upgrade
    Think it's an M10 60mm long bolt with a 1.25mm pitch thread. Need someone to verify as the other option is 1.5mm pitch thread... (readily available online and cheap)
    ks
    4G63
    thank you all....confirmed they are 60mm long, 10x1.25. Starter is in, truck is running!
    Naisu Happy motoring!
