			Freshman
					91 ram 50 12"lift build
							Got the front end brackets done to go up12" working on the steering next....mock up looking good so far ....im not using any donor parts I'm using all original ram50 parts just modify it if need to the only donor parts used was internal engine parts ....yes I found internal engine components that works in my 2.4 l 4 cylinder engine .....that motor is being used in my ram50 im driving now ......i think it's making big power for a 4 banger .....pulled out a f-350 and and a Tahoe on sand both were buried to the frame. Pulled both at the same time so impressed with the power it's making .......so I'm positive it'll have no problem turning those rrs I'm going to be using
