Results 1 to 8 of 8
Thread: What v8 will fit in a 1988 dodge ram 50?
    portland tn
    I kinda want to put a chevy 350 has anyone done this before.
    portland tn
    Dodge ram 50 4x4
    Newburgh, NY
    I think some have, and others are in the process.
    http://www.mightyram50.net/vbulletin...The-Fordubishi
    http://www.mightyram50.net/vbulletin...6616#post66616
    I'm sure there are others here.
    Of course, you could always try an inline-16, if you want to keep it simple
    https://jalopnik.com/heres-what-happ...her-1833107401
    Plenty of SB V8's have been done, no doubt you could go monster cubes with little trouble. The hurdle will be the 4x4 transmission. A RWD only swap would be simple - you may need to think about some radical fabrication and mods using a full size truck as a donor.
    Found this info. Apparently its possible to bolt right up to some of the tranny's that came with the mitsu/D50 https://www.forabodiesonly.com/mopar...-a-d50.396841/
    Lots of D50 v8 vids
    https://www.youtube.com/results?sear...ry=D50+with+V8
    Raymond New Hampshire, USA
    An inline 6 would be quite difficult. They are significantly longer than a v8. For a 4 wheel drive, you would probably want to do an engine/transmission/transfer case that all bolt together. Then modify the driveshafts to fit the new transfer case.
    Newburgh, NY
    Right, that's why I suggested the inline 16. seems pretty doable.
    LMAO, I totally missed that. That's hysterical. I'll have to look at that article in depth later.
