Results 1 to 4 of 4
Thread: Replacing front end-need advice
    Reno
    Bushings are gone from left and right.
    ball joints look squished to heck.
    grime buildup all over the control arm tells me it was never replaced since stock
    would like advice on items to replace the front end parts.
    Much appreciated in in this matter. Autozone/oreilly is getting rich off me
    so far I replaced the grill stereo tires shocks door assembly
    i want to replace the door panel foam, carpet and bench seat and I'll be done
    get urethane bushings for lower control arms, sway bar, and strut rod bushings - they are on ebay. check rockauto and ebay for ball joints, tie rods, pitman and idler arm rebuild kit or full replacement arms. lower control arms can be replaced if bad, as new aftermarket and oems are available.
    Reno
    Much appreciated photos will come up upon completion
    1993 Mitsubishi Mighty Max
