To accurately have the oil cog in the right position with the other gear markings on compression stroke, aren't you suppose to spin it by hand and it will sort of counter weight itself and roll itself into a position very close to the marking. If it doesn't It gets a 180 turn and then give it a light spin again by hand and let it go to see how it counter balances the movement in relations to the time mark..
