Results 1 to 3 of 3
Thread: 4G64 2.4 Photographic Engine Reference
    Many's the time I needed to look at a photo to see what placement was proper. I offer the following photos of my own 4G64, absolutely stock and all components are in their proper places.
    The only contention is the placement of the ignition wires: in these photos they go over the radiator hose. I have since opted to place them under the hose, to minimize subjecting them to heat.
    Identification Tag on Firewall [v] (top of photo under red v) - Tells you your engine number (i.e. 4G64) and original paint code
    General Engine Layout
    Timing Mark On Cylinder Head
    Engine Layout
    Arrow points to Silent Shaft Access Bolt
    Oil Pump-Side Silent Shaft Access Cap [photo by Camoit]
    Ignition Timing Jumper Connector Location
    A variety of information is also available HERE
    These photos may be of use to several members working on timing issues right now. This is the 2.4 engine, very similar to the 2.0.
    royster
    Georgia
    1984 Dodge D-50
    4G63
    Thanks royster......................
