How far in does the screw driver go?
When you put it in there and turn the shaft can you feel it turning on the screw driver. The counter shaft has a flat side so you may need to turn it about 180 degrees. If worse comes to worse you can always set the cam and crank and put the belt onto the shaft last while holding it in position.
