Well where should I start. First off my truck a 95 Mitsubishi mighty max 5 speed with the 2.4 4g64 motor with about 157000. When I bought this truck it was my intentions to do anything with it but that quickly changed. This truck is just a fun little truck to drive. After driving it about 2000 miles its started to smoke when you first start it up. First thing I checked was the compression. The issue I found was to be the valve seats. Compression came out at 140, 140, 114, and 120. No good. So right there I decided to just pull the motor and rebuild. My intentions are not to boost performance or anything so I think the stock 4g64 sohc will be great. I might do minor work like port match the intake and head, ram intake, emissions delete, and maybe some bigger injector if anyone has any advice on that. Well I tore down the motor and will soon be getting it to the machine shop for cleaning and having the cylinder and crank looked over. Everythings looks excellent to the eye but we shall see. I will also be having them flatten the head. I will do most of the work myself once the shop tells me if I need oversized rings or anything else. Does anyone have any experience with the DNJ kits? I was looking into that as a budget option. Of course I'm going oem for the waterpump. Anyone have any advice for a beginner to these trucks? What could I do for small performance gains with very little money while I'm in there. I really don't want to do the dohc swap. It seems like a lot of work and I'm on a pretty tight budget. Plus I really like the look of the stock sohc. All advice and comments are welcome. Thank you for taking the time to look.
