Ignition Timing Procedure
The 2.4-liter engine has an ignition timing of 5 degrees before top dead center (BTDC). First, connect a jumper wire between the ignition timing adjustment connector and ground. Then, turn the car on and put the transmission in neutral with the emergency brake engaged. Finally, turn the wheels clockwise and bring the engine to an idle speed of 750 rpm. You can check and adjust the ignition timing after these three steps are completed.
Read more:
http://www.ehow.com/facts_7889576_mi...#ixzz2rtWDnlcz
