OK. I have it in with two bolts on the bottom, the cross member back in and the drive shaft and center bearing back on. Taking a break.
Its surprising how much lumber you need to install one of these on your own with it just high enough off the ground for the bell housing to fit under. I levered the front and back up and cribbed it until it was high enough for the jack to get under it. It is good to have a 3/4 plywood about an inch larger square than the pan a bunch of short 2x4 and a short 4x8 only because the little jack doesn't get up very high. I needed both the floor jack and the little cheapo floor jack to get it into position at the same time. Once I had a bolt seated with it on the projecting studs I only needed the one jack. Don't connect the cross member to the frame until you have the mount nuts and bolts in hand tight. I just need to put in the top bolts and the starter.
I'll be using Redline MT90 oil.
