I'll look around. Or I'll send flywheel to top end and let them lighten it and redrill for the bigger clutch. Idk yet.
No not a 65, still might balk at doing it. Tell them it's from the "last" L88 427 tripower Corvette convertible built. There may be some liquid on the floor after that... BTW, I go to some of the auctions seems there are like 10 of the "last" Corvette built or the same car gets sold at every auction. We also need to make sure that Carrie Underwood is denied membership here after the line in her song "took a key to the side of his pretty little souped up four wheel drive". An obvious truck hater, just sayin.
Get yourself an electric cooling fan as well. Not a huge power saver but can't hurt. Maybe think about deleting the egr valve too. Unless u have to pass a smog test.
how would you set up the throttle for the 38?
or how did you? id like to run a 38
I haven't done the 38 yet. Don't even have motor together yet. Bought a plymouth arrow I'll b showing you guys soon.
Get a 200hp shot of NOS. That should do the trick.
