Originally Posted by
I made my blockoff plate out of some scrap s/s sheet I cut out of a poker machine to install a bill acceptor - I used the spacer as a template. There is no oil pressure against it, and not a real high temperature, so as long as you use silicone form a gasket to seal it, you could use heavy gauge sheet steel to make the plate. As for the vac advance, connect it to the fitting on the carb above the throttle plate - its the ported vacuum fitting and is different than full vacuum from below the throttle plate. Ported vacuum will increase and pull the vac advance as the throttle opens, whereas full vacuum drops as the throttle opens, and the vac advance will not move.
