Hi all, looking for a little advice on carburetors here. I have a 1982 Dodge D-50 Royal. 2WD, 2.6L, 5spd manual and my Mikuni 32-35 DIDTA carb is toast. I do not have to pass emissions and am trying to decide whether or not to buy a Weber* kit or a rebuilt Mikuni from Rock Auto. Also, I'm having trouble trying to find what Weber would even fit my truck. It doesn't look like they are available through Redline and I don't trust eBay or Partsgeek. Any advice would be appreciated.
I love that little truck and just want it to run well. My father bought it new in 1982 and it was my first vehicle when I was turned 16. It was the first vehicle I ever worked on and it got me interested in wrenching. All maintenance and repairs have been done by my father and I. Below is a list of what has been done to it...
• Full engine rebuild and new head
• Aftermarket exhaust header (Pacesetter I believe)
• Custom air cleaner (thermostatic valve removed and vacuum line capped)
• CAT removed
• New clutch
• Fully rebuilt transmission
• New NGK plugs, Bosch wires, ignition coil
• New fuel tank, fuel filter, fuel pump, fanbelt, all rubber fuel and vapor lines, hard lines blown out
• Check valve tested, two-way valve replaced
• Charcoal canister rebuilt and filter replaced
• Carbon cleaned intake manifold
• EGR valve cleaned/tested
• Distributor tested
• New radiator, coolant hoses, thermostat
• Rebuilt front end
