Originally Posted by
Salteen
i have said it in another post ill say it here, dodge has some DOHC V6 engines that are as big as 4 liters. thats pretty big. slap a turbo or 2 on it and bam. best part is its based off the 6g engines. so it probably has the same bellhousing pattern. you still need to check with the flywheel and starter and make sure it will work. I am a 4 cly i6 v8 guy myself, but a v6 can be a good engine if you do it right.
the dodge versions I think may have been 60 degree Bank if I'm not wrong that may just be for the OHV models. that would mean there is a bit more room to work with. hell you could do alot of stuff with a 60 degree Bank. you could do a moniker like I am! I really want a 2WD truck to build for a moniker but I can just call mine the SRT4 4x4 edition. Do you have any pictures of the truck? exactly what is it, ram 50, mighty max, arrow, L200, raider, montero, what?
