mightyram50.net • View topic - 2.6 (g54b) turbo swap project thread
Re: 2.6 (g54b) turbo swap project thread
Postby natureboy » Sun Oct 25, 2009 5:02 pm
Bless you TurboMax!! I know it's a lot of time and effort to post all of this info again, but it's definitely worth it. I appreciate it, anyway. I'm half heartedly considering the turbo swap for my truck, and your pioneering effort is very valuable. Thanks! :clap: And NO, I have no interest in a 4G63t swap.
natureboy
Engine Size: 2.6l
Postby TurboMax » Wed Oct 28, 2009 3:30 pm
turbo ram wrote:Grate job Turbo Max on all this useful info on the swap, not only are you explaining it but you also have pics and diagrams is awesome.I ran into the same issue with my a/c and had to mod my existing brackets and fab new pieces. The main reason was that the compressor that was on my truck wasn't that common and hard to come by so I found one that was more common and that could easily be found out at the jukyard. I flushed the system which was quite dirty and vaced and filled and it's been ice cold.
natureboy wrote:Bless you TurboMax!! I know it's a lot of time and effort to post all of this info again, but it's definitely worth it. I appreciate it, anyway. I'm half heartedly considering the turbo swap for my truck, and your pioneering effort is very valuable. Thanks! :clap: And NO, I have no interest in a 4G63t swap.
Thanks. I'm just trying to help those doing the swap. There's been a few 2.6T swaps done here, just not enough info available especially since alot of info was lost on the old site.
TurboMax
Engine Size: 2.6T
Postby 4g63mightymax » Wed Oct 28, 2009 5:51 pm
Although I typically lean towards the 4G63's, I also very much appreciate your 2.6L truck and the build thread as well. The awesomely factory-looking swap that you have done is exactly how I would have done it. Very well done!
-Jeremy
4g63mightymax
Postby TurboMax » Fri Oct 30, 2009 10:47 am
4g63mightymax wrote:Although I typically lean towards the 4G63's, I also very much appreciate your 2.6L truck and the build thread as well. The awesomely factory-looking swap that you have done is exactly how I would have done it. Very well done!
-Jeremy
Thanks again.
TurboMax
Engine Size: 2.6T
Postby conquest232 » Tue Dec 15, 2009 5:51 pm
turbo swap ,,im doin this same swap,,,the motor is in,, wiring is my hold up...
i have the starquest harness installed along the passenger fender,,and connected to the
motor
,,,now,,,
the ecu has three plugs,,,two of which go to the engine,,,then the one that goes over to the ,body harness
wat did you do for that harness?wats wires did you use??,,or did you use that whole harness???
lmk
thanx
bryen
conquest232
Engine Size: 2.6
Postby conquest232 » Tue Dec 15, 2009 5:54 pm
hey sorry man,,,i found your write up....very nice job,,,great info
thanx
bryen
conquest232
Engine Size: 2.6
Postby TurboMax » Tue Dec 15, 2009 7:21 pm
conquest232 wrote:hey sorry man,,,i found your write up....very nice job,,,great info
thanx
bryen
Good luck on your swap. If you run into any problems feel free to ask and I'll help if I can. Also, if you have a chance start a project thread with of your swap and include some pics.
James
TurboMax
Engine Size: 2.6T
Postby TurboMax » Thu Apr 29, 2010 4:10 pm
Went ahead and worked on adding the rear factory flare on the driverside. Had to cut the flare some due to my rocker panels. On the plus side, it looks like I gained an inch of lowering due to the flares (flares extends 1" below wheel well). :)
IGNORE THE WHEELS, STILL HAVEN'T CONVERTED THE REARS TO 5-LUG YET.
TurboMax
Engine Size: 2.6T
Postby LethalEthan » Thu Apr 29, 2010 4:21 pm
looks awesome. ive been waiting for someone to put the stock flares on a dropped 2wd.
LethalEthan
Engine Size: 2.3L
Postby TurboMax » Thu Apr 29, 2010 4:34 pm
LethalEthan wrote:looks awesome. ive been waiting for someone to put the stock flares on a dropped 2wd.
Thanks.
Here's pic I downloaded from the old site you might like. The rear flares also have been modified to fit the custom rear bumper.
TurboMax
Engine Size: 2.6T
PreviousNext
Return to Turbo Builds and Engine Swaps.
