lifts for mitsubishi mighty max
A place to introduce yourself and get aquainted with the other members.
Come on in, we don't bite!
Forum rules
Postby mightymaxjake » Mon Jan 24, 2011 2:50 pm
does anybody know if they make a suspension lift for a 1991 Mitsubishi mighty max 4x4
mightymaxjake
Engine Size: 6cyl
Re: lifts for mitsubishi mighty max
Postby pennyman1 » Mon Jan 24, 2011 5:18 pm
See sway a way post for torsion bars, use 2nd gen montero upper control arms for 2" more lift in front. flip axle to bottom of springs for 4" lift in rear - make sure you keep pinion angle as close to stock as possible.
pennyman1
Postby mikewarme » Thu Jan 27, 2011 5:56 am
Without major mods I wouldnt do it. With a torsion bar set-up don't expect big results unless you do SAS. Tires rub in fender wells easy on these. So watch tire size!
mikewarme
Engine Size: 2.3
Postby 4D55 Performance Inc » Thu Jan 27, 2011 10:23 am
Short of doing a solid axle swap your best bet is doing a combination lift (suspension and body lift). Like Mike, I also recommend getting the Sway-Away torsion bars to lift the front end about 2" and longer shackles to lift the rear about 2". Then I would add a 2" body lift. This will net you about 4" of total lift. I would also recommend getting some 4.62 gears out of a Montero so you can run 33-35" tires with this setup. If you're somewhat handy with tools I think you could do all this (tires excluded) for $500-600. The CV's on these truck are pretty stout and have been proven to with stand the punishment of running 35" tires.
By only cranking the torsion bars 2" you avoid having to replace the drive shafts which can get pricey. If you have any other questions feel free to ask.
Here is my pickup with 14" lift via an SAS
Engine Size: 4D55
Return to Newbies
