[phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /viewtopic.php on line 1052: getdate() [function.getdate]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected 'America/New_York' for 'EDT/-4.0/DST' instead [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4505: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4507: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4508: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) [phpBB Debug] PHP Notice: in file /includes/functions.php on line 4509: Cannot modify header information - headers already sent by (output started at /includes/functions.php:3706) mightyram50.net • View topic - 5-spd (3.0 4x4)
A site for Mitsubishi Mighty Max and Dodge Ram 50 Enthusiasts.
curious....which trans is that? my understanding was all km132's (even the v6 version) had the bell housing as part of the case. seeing the bell housing bolts on, i'm guessing that is a V5M31 from a newer montero 5spd 4x4...much stronger unit! if that was the super rare R5M31(foreign market only 2wd version) i'd be all over it!
