We are up and running. But she is not at full power yet. It's in Beta test SO take a close look between FAQ and MEMBERS in the header. This will change over time as I progress. The station will also be down from time to time. so go ahead and give it a try. I sugest you have some speakers with a self powerd sub woffer, or head phones.
Here is where to find it. Just go to the top of any page of the site. It will only show up for members.
If you don't see it you need to log in. Just click the Radio link.
This will bring up the player.
Now click the Station ID on the right side of the player, it will conect to the stream.
If you have any problems with the player going into the
"BUFFERING" mode then the fix takes 10 seconds. Just right click the "BLACK PART" of the player, then right click options. Select the buffer setting. Now change it to 20 or more. It depends on your internet conection speed. the slower the speed the higher the number. 28K Modem = 50 OR More Seconds, : DSL = 40 seconds, : Cable = 25 Seconds, Fiber Optic T1 or T3 = 10 Seconds or less.
Now if you want to see what is in the Library of 2000 songs. For now you can go here. [url]
http://rcip.com/ducatim900/radio/playing.html[/url] It's a long way from done. But it's so cool what this thing can do. Here is the Play List CUE.
http://rcip.com/ducatim900/radio/playing.html It shows what's getting played next. Once it's done you will be able to look at the Library and click the request button. It will then put the song directly in the cue to get played next.
