Doctorates Degree
You can buy 43" x 15" black ABS honeycomb grille sheets from ebay and either make a complete custom front grille from it or graft it into the factory grille (handy if your grille is broken and you wanted to try out something different) Cutting down the centre section from the grille of a Chevy Tahoe or Blazer would work on a gen 1 truck with a bit of imagination.
