Does this look correct?
If it's smoking black out the pipe then you are getting to much fuel. The choke might be stuck closed. The float may have sunk.
Direct link to images.
http://www.mightyram50.net/camoit/smog/85-96-smog1.jpg
http://www.mightyram50.net/camoit/smog/85-96-smog2.jpg
Hello Camoit,
Thanks for the diagrams. The smoke is white and the motor shakes like it is not firing right. It's not a cloud of smoke where you can't see through it, but as if it needs a tune up. I don't know what else to do. I know who ever had it last cut some wires and there are some vacuum lines plugged off.
For instance, the wiring harness that goes to the alternator, has a thick wire that screws onto the alternator in the back. Then there is a Black plug that has 2 small wires in it that plugs to the back of the alternator. Then there is this yellow wire that is with the other wires, but it is cut and just laying there attached to nothing?? What a mess it is under this hood.
Oh, forgot to mention, mine appears to be the 2.0 Liter
