Results 1 to 9 of 9
Thread: leaf spring front main eye bushings?
    Upstate, SC
    Anybody know where to find these which have the inner and outer shell? I cant find them anywhere. Mitsubishi wincap program dosent even show the bushing or part number. Autozone and advance dont have them and the ones they do have for a 4wd dont work.
    Also do not buy the rear Energy suspension kit. The main eye bushings are too small. That is where I screwed up, i cut out the old bushing for them to only find out that they dont fit and now now replacements cant be found. I called energy and they are working to find me some that will fit. But if they also dont fit Ill need some sort of replacement.
    Try contacting these people by phone. Pick a location close to you.
    http://www.bettsspring.com/
    I have used them in the past without problems, but I haven't bought a set in years.
    Nyssa, Or
    1982 Dodge Power Ram 50
    Try this, even if only for a p/n to cross.
    http://www.factorychryslerparts.com/
    Ronkonkoma
    1991 Mitsubishi Mighty Max
    The urethane bushings for the main eyelet didn't fit my truck either. I had to drill cut and burn the original bushing out of its metal case. I used that metal sleeve for the new bushings. Then the problem with the bolt hole... I used a piece of 1/2" copper pipe the same length as the original metal center sleeve and then used three 1/2" couplers over it. The third coupler had to be trimmed. This got me to just about the perfect fit everywhere.
    Lynchburg, VA
    I know this is a older thread but I too had the same problem with the front spring bushings from Energy Suspension. I called to tell them and they told me they don't sell many. Told them the reason is probably because people buy them, they don't fit and require a custom engineered solution and the word gets passed around. Anyway, they want me to measure up the truck spring parts for them so they can correct the problem. I told them to buy a stock bushing and measure. I guess I will send them measurements, you would think they would refund me my $26 for this assistance.
    manchester, tn
    Hi guys I know this is a older thread but I want to spread the word. I have a 4wd but I was able to find polyurethane bushing for the front leaf bushing from Siberian bushings out of Russia. It is an exact fit. I have looked for a replacement for over a year and found them cross referencing the mitsubishi l200. Cross reference some of the foreign models. Siberian bushings has a website I paid $33 for a set shipped package arrived within a month.
    I was going to post the same info - there are also torsion bars by sway-away for the swb 1st gen Monteros that will work in our 4wd trucks - they are 375 / pr but they are available. Look at this link for both the bushings and torsion bars: http://shop.adventuredrivendesign.co...ory&path=71_72
    Esparto CA
    I bought an energy suspension bushing kit and it worked just fine for my 82 4x4
