Page 2 of 2 FirstFirst 12
Results 26 to 47 of 47
Thread: Truck struggles under acceleration
  1. #26
    Gilbert, AZ
    1980 Plymouth Arrow Truck
    Blocked jets - try purging the carb. Engine running, cover the throats of the carb with one hand while opening the throttle. This will force the carb to pull excessive amounts of fuel through the jets and sometimes this is enough to unblock them.
    Suggested it on an earlier post on this thread.
    Well that didn't work. I guess I can take the top part of the carb apart and clear the nozzle that way...
  2. #27
    Gilbert, AZ
    Hmm. Looking at this youtube video, is it possible that the other side shouldn't have a hole?
    https://youtu.be/jlEXR2hXUFg?t=163
  3. #28
    It shouldn't as the accelerator pump jet should only feed the primary throat. It should have a nice steady stream of fuel coming out of it when its operating properly. You can see they're relatively easy to pull apart and you don't have to remove the entire carb from the manifold to work on it so if the accelerator jet is blocked, you can take it out and push some compressed air through it.
  4. #29
    Gilbert, AZ
    Ok. I think my accelerator jet is fine then. Once I changed the gas cap & accelerator pump I get a good stream from the jet on the primary side.
    This leaves the fuel pump I think...
  5. #30
    Seattle, WA
    Here's a thread from a Jeep forum where a member has a Weber with the same no-load and with-load stumbling you're experiencing.
    https://www.jeepforum.com/forum/f12/...-opens-867114/
    Some of the replies mention possible causes, things to investigate and tests to try. I'd ignore suggestions to change jet sizes, especially if it ran fine before the hesitation problem appeared.
  6. #31
    At this juncture I'd think about an electric fuel pump install which is always advised when doing a Weber swap. Depending on what pump you get, you can do this relatively cheaply and they're easy enough to rig up. Guys like the Carter P4070 fuel pump but I'm not a fan. They're expensive and noisy - plus I've had one fail on me (not only did it fail, but it caused issues downstream of the fuel pump when it coughed up a heap of fine brass shavings)
  7. #32
    Gilbert, AZ
    So basically I need an electric pump, and a relay to kick the pump on when the ignition is on. Correct?
  8. #33
    Yep. Use the hot wire that originally went to the carb as the trigger for the relay, and have the main power feed fused straight off the battery to the relay and out to the pump.
  9. #34
    Cant Say
    Dodge V6
    thats what i am doing, pretty simple and straightforward
  10. #35
    Raymond New Hampshire, USA
    I would hook a timing light up before you go to town on the carb. An ignition stuck advanced will cause sputtering and backfiring under load.
    The weber accelerator pump nozzle looks the same for both the 32/36 and 38/38. They use the same casting. The 32/36 only has a nozzle hole drilled on the primary barrel side however. It is normal for a 32/36 to only have one stream of gas. The 38/38 has both nozzles drilled. The speed at which you open the throttle determines the flow of gas. Open the throttle slow and it will dribble. Snap it open and you should get a stream. Failed accelerator pumps only cause momentary hesitation on throttle opening however. They bridge the gap between the idle circuit feeding the engine and the main circuit running the engine when you open the throttle.
    If it's fuel and not ignition, rough idle can be caused by fuel starvation or over fueling. Fuel starvation at idle, and there probably wouldn't be enough fuel to feed the engine running down the road. Rough idle and running caused by over fueling is usually smoothed out when you open the throttle.
    Acting fuel starved and over fueled makes me think the ignition system may be to blame. Can't hurt to check it out.
  11. #36
    Somehow I missed the second page when I replied to this. One thought, a mechanical pump could be underperforming at low engine speed and overwhelming the carb at high engine speeds. So while it is possible that it is ignition like I thought, I would definitely install an electric pump as recommended. My truck came with a stock mechanical pump and a Weber installed. It ran much smoother when I went electric after the mechanical pump failed. But not before I replaced the mechanical pump and it failed again a few months later.
  12. #37
    Gilbert, AZ
    I think I'll do the pump swap first, Giovanni, and see where that gets me. Hopefully all the way.
    Geezer is this the pump you recommend?
    https://www.ebay.com/itm/Top-Electri...n/292173987502
  13. #38
    That's the one. I've bought that pump for my Weber install but I'm not ready to swap everything on my engine. This should (hopefully) solve your fuelling woes.
  14. #39
    Gilbert, AZ
    I have some more questions... What is this thing here that the vacuum line is attached to:
    And what's this black thing in the red circle, and what's this vacuum line in the blue circle for?
  15. #40
    The thing in image #1 is a vacuum triggered switch. It has come up before on the site and performs some kind of 'ignition on' circuit connection. A member had one fail recently and their truck wouldn't run. The thing in the red circle in image #2 is a vacuum barb cap that I think is part of the EGR system. Trace the vacuum hose in the blue circle to wherever it's going. It might be going to a control circuit or scavenging vapour/gas from the valve cover.
  16. #41
    you'll have to follow the blue circle to find out where the hose goes. red circle, the cap is ported vacuum port. typically the vacuum advance on the distributor is hooked to ported vacuum. The lower hose is manifold vacuum port. some folks hook the vacuum advance to manifold vacuum. They are the same except when the throttle is closed. manifold vacuum when the throttle is closed provides a full vacuum signal. ported vacuum kills the vacuum signal when the throttle is closed. Personally, i find ported vacuum to be better. It provides better engine braking, and acts the same from part to wide open throttle. If your vacuum advance is hooked to the manifold vacuum, i'd recommend swapping the hose and vacuum cap.
    As geezer said, that vacuum switch prevented someone else's truck from running. You could unplug the connector, attach a jumper, and see if the truck will run.
  17. #42
    Gilbert, AZ
    Any recommendations for fuel pump relay kit?
  18. #43
    OK. The red circled port must go to the vac advance on the distributor.
    The other vacuum switch you show on the firewall is the AC idle kick up. But since you have a Weber it does not do anything anymore.
    As for the relay you would just use any old relay. You just build the wires.
    The reason you have no power is because the vac advance is not working correctly.
    You should have a manual what came with the carb. If no there is one in the manual section I think.
  19. #44
    Gilbert, AZ
    Why would the carb run fine for years then? I will try that and see what happens... just confused as to why its been fine and all of a sudden this symptom has come up.
  20. #45
    It has to be a mechanical fault or the pump has quit it's day job (or a combo of both). There is a specific clue that's eluding you at the moment. Once you spot it you'll get it running like new. If you have to pull the carb apart to inspect it, well that's just how it goes. Hopefully you'll fix it soon and get your power back
  21. #46
    Gilbert, AZ
    Installed an electric pump with relay and that fixed all my issues. Starts way faster & easier now too. I have a block off plate for the mechanical pump, I may take it off and open it up to see what went wrong.
    My dad seems to think that the ethanol in our fuel could have deteriorated the innards in the pump. On that note I've started adding this to my fuel:
    https://amzn.to/2SGxWUq
    We'll see if that helps.
  22. #47
    Yeah ethanol is sketchy if you haven't modified fuel delivery to handle the stuff and it will affect tuning without rejetting the carb to run on it. I've gotten into the habit of adding synthetic 2 stroke oil to my DD with premium fuel (95+) It runs like a top - I'm only using 100mL for every 10 L of fuel but not on every tank (maybe every second/third refuel...) The fuel stabiliser is a good idea if you drive your car only once every few weeks.
