well i included pictures of my truck on intro . my plans for this MM is basicly stock. (for now) something blows up may be different story.here are original pictures.mighty max 015.jpgmighty max 002.jpgmighty max 003.jpgmighty max 004.jpgmighty max 005.jpgmighty max 006.jpgmighty max 008.jpg now for some updated pictues. i have just done minor repairs and some cleaning so far.mighty max 022.jpgmighty max 023.jpgmighty max 016.jpgmighty max 017.jpgmighty max 018.jpgmighty max 019.jpgmighty max 020.jpgmighty max 021.jpg . so rear shocks.. rear shackles bushings.. rear brakes.. front brakes hoses and pads clean and unfreeze acouple front brake sliders ..bleed brakes and change rear differental fluid have been done so far.. still need to do timing belts and find a fan shroud..should have done timing belts yesterday but had worked two 14 hour shifts monday and tuesday and regular yesterday so did not feel like doing..But i did do a little simple green cleaning under hood..mighty max 025.jpgmighty max 026.jpgmighty max 027.jpgmighty max 028.jpgmighty max 029.jpgmighty max 030.jpgmighty max 031.jpgmighty max 032.jpgmighty max 015.jpgmighty max 024.jpg so i am going with the stock rims painted black chrome lugs.. will be putting 205 70/r14 tires on front 215 or 225 70r114 rear.. l(looking for 14 inch trim rings for wheels) . would like to find a rear sway bar set up?>(any one have a picture of what stock looks like) ? how are the after market sway bar kits? still need to replace all 4 ball joints (still tight) leaking grease and replace front sway bar end bushings. well that is all for now.
