Results 1 to 3 of 3
Thread: 2wd lift?
    Houston, Texas, United States
    2wd lift?
    Okay so I have a '88 MM 2wd, is there a way to lift up the front up to make it even with the rear? I don't like that the rear sits higher, trying to stuff some 235/75r15s on it. Any one know how to?
    Payette, ID
    Rubber bushings under the coil springs and longer shocks would be my guess. My 87 4wd was way easy to lift the front, i just had to turn 2 bolts!! (Torsion Bar) Its sad that my 2wd short box bottoms out on less than my 4wd long box lol!
    http://67.122.16.100/larsdennert/4ru...rearspacer.jpg
    1987 2WD Mitsubishi Mighty (R.I.P)
    1984 4WD Toyota Pickup (Sold 10/12)(Rolled and Totaled 3/24/13)
    1987 4WD Power Ram 50 Custom (Scrapped)
    1991 2WD Ram 50 (Scrapped)
    1992 Ford F250 7.3 (sold)
    1999 GMC Yukon (DD)
    1988 Ram 50(project)
    New springs in the front and there local to you.
    (This make a perfect example why we ask for location when registering.)
    Draco Springs Co. http://www.purplespring.com is the automotive division of http://www.dracospring.com/
    You will want to talk to Rob Fuller tell him the off road guy in Sacramento from Mightyram50.net sent you. It might be the best way to go, and he can use you as the default spring rate for the rest of the guys on the board that want springs. Lifted or lowered.
    7042 Long Drive Houston, TX 77087
    Rob Fuller
    704-232-6990
