Results 1 to 21 of 21
Thread: caddy rims question
    shafter ca
    Please Select Engine Type
    Cool caddy rims question
    has anybody painted cadillac rims and if anybody has do you have pictures cus im debating if i should paint them or not or is there a way to find out how they will look?
    Chesterton, IN
    1991 Mitsubishi Mighty Max
    what color you thinking? i have powder coated a few sets but no pics..they look nice when done correct.
    Savannah, GA
    the insides of mine we're painted black, left the face polished
    shafter ca
    im thinking gloss black and red i was looking at a picture of one last night and liked it im also thinking about it for
    the color of my truck cus thats my next project
    shafter ca
    nice truck by the way!!!
    Tulsa, OK
    Nice touch painting the inside. I plan on painting mine all black.
    shafter ca
    this is what i foun online
    Tulsa, OK
    Looks like the link is broken.
    shafter ca
    yeah i havent been able to post it but i have it in my profile
    shafter ca
    C:\Users\nathan\Pictures\New folder\caddy rims.jpg
    shafter ca
    how do you post pictures in here?
    Tulsa, OK
    shafter ca
    thats the one haha
    Quote Originally Posted by tj mightymax View Post
    Take a look under site news and support. There is a hole how to in there, along with the FAQ area.
    Portland, OR
    Rattlecan instructions for piano black (wheel material don't matter much):
    Clean rims thoroughly.
    Scuff with scotch bright or medium-heavy grit sand paper.
    Clean/dry rims again, use tack cloth to remove any residue.
    Mask the bead area and general tire area of wheel (possibly lug nut holes, as well).
    Spray wheel with Self Etching Primer, let dry.
    Spray gloss black in 2-3 coats. Let dry and cure for at least 7 days.
    Wet sand, clean, dry, tack cloth. Spray 1-2 coats again.
    Let cure at least 7 days.
    Spray 1-2 coats clear. Let cure at least 7 days.
    Rinse/repeat with clear. Can do this another time for a deeper gloss.
    Final wet sand after final curing with a VERY fine grit. Clean up well, tack cloth. Use a quality polishing compound or clay bar.
    Finish with a well buffed coat or 3 of carnuba wax.
    Considering this idea is for wheels, I would use high-temp engine paints. Black and clear.
    Keep in mind this will be a high maintenance finish on wheels. They take a lot of road grit, brake dust, and heat.
    These instructions were actually posted for use on computer cases, but beyond wear and tear, the process should be the same. Powder coating might be a better option all around.
    Tulsa, OK
    Nice "How-to" Acuta73!
    shafter ca
    cool thanx
    Chesterton, IN
    21 days later "at least", youll be able to drive your truck...lolj/k
    shafter ca
    i guess you could speed up the drying time with a heater in ur garage !!!!
    Portland, OR
    Quote Originally Posted by Payrion View Post
    It's all about the shine and that means curing time before you touch the paint again. Still not sold on how well this'd work for wheels, but it'd look GOOD for at least a while. Might have to be wet sanded and clearcoated again at least once a year. Really not sure.
    As I said, this was a guide for painting computer cases. They usually don't roll down the road (ideally). lol
    shafter ca
    just like any other paint job and also depends on what kind of paint you use!!!
