mechanical valve adjuster .....how about changing the valvesprings designed for 130mm valves? the primary reason i'm thinking of going to a shorter one is to lower the compression ratio. but still debating myself on this one. don't know yet what will happen with the power band? how would the hp and torque behave with a lower cr?
