Results 1 to 5 of 5
Thread: Tranny help needed
    Keystone heights,fl
    1989 Dodge D-50
    Tranny help needed
    Hi I have an 89 d50 I just bought it had a fried motor. So I replaced motor and tranny, but instead of an automatic I put a manual in. Now my ignition will not work due to the neutral safety switch. Does anyone now how to bypass this. Please help
    I had to switch out the backside of the ignition switch with the one from a manual steering column, where the wires are, then i still think i had to run a wirr directly from the switch to the starter because i still couldnt figure out the damn neutral safety switch or where it was.
    Look under the carpet on the right side under the seat. There is a plug under there that you need to jumper. Thats where the safety SW plugs in.
    Keystone heights,fl
    1989 Dodge D-50
    Camoit which wire do I need to jump I found the plug but there is 7 wires that go to it.
    uhhhh yes.... look in the manuals under the first gen factory manual. I think the wire colors should be the same. But I don't know for sure. If you use a test light you will find the hot wire when the key is turned on.
    Also look in The over 216 manuals for a wiring dig for your truck. Look in there first.
    Then you can back feed the wire from the starter side and use a test light to find the other wire.
    oh oh oh.... if you have the neutral switch look at it for the wires and test them with a volt OEM meter.
