Results 1 to 6 of 6
Thread: Lost oil pressure on my 2.6
    Folsom, California
    Just recently purchased a 1981 Sport with 75k original miles that has been sitting since 1997. The guy i bought it from did a little bit of work on it after getting it out of indoor storage and lost interest and i bought it. I only drove it about half a mile total as the entire fuel system needed replaced. i have that all done but now but it has since lost oil pressure. The oil pressure gauge worked when i bought it all though it did not seem like it had much oil pressure. The head is new and looking down the oil fill everything inside the head looks new.
    I changed the oil and filter and have started it for about a total of 2-3 minutes. I took the oil sensor out of the block and turned the motor over and no oil came out. I checked the oil filter and it did have oil in it so that confuses me a little bit. I have a sensor for it and installed it but that wont fix anything. Can this motor somehow lose prime in the oil pump? I am out of easy ideas and my thoughts were to pull the oil pan and check the pick up tube for blockage, o ring etc, gasket etc first. If that all looks good I tear into the front of the motor and possibly replace the oil pump.
    does that sound like a decent strategy going forward?
    is there anything else i can do to trouble shoot it before i get inside the motor?
    tucson az
    4G61
    if it was me I would buy a cheap oil pressure gauge.. and install it with the sensor it comes with and see if u get pressure on it (at startup for like 10 sec just to test it).. if no pressure still.. then i would drop the pan and check the oil pickup tube.. then i would do the pump after all that.. hope this helps..
    Folsom, California
    i bought a oil pressure test kit. i was just scared to start it but i will give that a try and see what happens.
    thanks for the reply
    North Dakota
    Keep us updated. I'd be interested to know what you found.
    Note the block threading for the oil pressure gauge sender/warning light switch is BSPT threading, whereas an aftermarket gauge or test kit will prolly be NPT, so you may need a BSPT to NPT adapter (I found one on eBay).
    Folsom, California
    Luckily the kit I bought had the correct fitting. Unluckily ZERO oil and oil pressure
