suspension geometry changed after lowering 2in ( 1993 mighty max 2wd )
I have a 1993 mighty max 2wd. I lowered front and rear by 2in. I used lowering spring in the front and lowering blocks in the rear.I feel the steering becomes heavier and tire squeaking when turning at medium to high speed. Definately not safe to drive on high way. I think maybe camber or toe (or both) have changed after lowering that much.What are the common fix to this? Toe-in should be pretty easy to adjust. How about camber?
Junior
did you go get a alignment? if not then you need to.. any change like lowering or raising will require an alignment
