Trying to help my neighbor. He has a 1987 ram 50. He replaced the 2.0 with a 2.4l. It ran one time and then nothing. It cranks but no spark. The distributor is from a 2.0l and was replaced with module & pickup. Coil also replaced, new plugs. No spark at coil wire or plug wires. 12v with key on at resistor block and coil. The carb was replaced with a Weber carb that ran with old engine. Does this truck have a ECM? Found something that looks like one by glove box. If so how do you check it? Not sure on the wiring from distributor. Blue wire going to negative on coil. The other wire goes to resistor block with the two black & white wires. Need some help on where to go from here. Thanks in advance.
