Results 1 to 10 of 10
Thread: 4g64 swap into my 86 G54 pickup
    Red Feather Lakes, CO
    My 1986 Power Ram pickup runs fine, i rebuilt the motor during our Covid vacation, I put the 38 Weber carb on it and have Hooker super comp headers on it. Yes it's 4wd, 5 speed manual.
    I found a pickup cab complete with motor, 5sp 4 wheel drive transmission and driveshafts. It has a 1991 4g64 motor. It was supposedly rebuilt before somebody chopped the bed and frame off to make themselves a trailer.
    So please give me all opinions or experiences or advice you may have about me removing my perfectly good 2.6 liter and swapping in this unknown 1991 4G64 .
    I'd like you to tell me I'll get better MPG and better horsepower and even better reliability with the fuel injection... but I don't want to assume it hope for that and later find the swap wasn't worth it.
    Should I expect that the gearing of my 86 rear axle should match the gearing of the 91? Or should I just swap motors and keep my transmission in place??
    Thanks again, guys, in advance. You've always been so helpful through the years and this feels like a big project I might regret?!??
    Bill
    Is the 4G64 an improvement over the older G54b carburetor motor? Better power? Better gas mileage? Longevity? Even if you may not have personal experience doing this swap I'd appreciate any opinions or ideas. Thanks in advance! Bill
    miami, fl
    1991 Dodge D-50
    if you have a good running 'fresh' 2.6 you're happy with, I'd probably stick with that
    Dunno if the old 4x4wireforums still up, but I recall one guy doing a starion 2.6 swap, saying...
    he got the 2.6 swap running before adding the turbo, and he preferred that stock 2.6 TBI over his weber carb 2.6 replaced
    The MPI 2.4 is a VERY good running simple smooth reliable motor..... sans the common era mitsu(& toyota) ecu capacitor issue
    I purchased a $150 Mmax with no gearbox & firewall tear(common at clutch cable pass-thru). Purrs like a kitten. Turbo is the plan
    If you had a place to 'store' it and got it for a deal.... I probably would. Also need the 2.4 EFI fuel tank, lines, loom etc
    A post or two, here on 2.4MPI replacing old carb motors
    he got the 2.6 swap running before adding the turbo, and he preferred that stock 2.6 TBI over his weber carb 2.6 replaced...
    For that matter, just converting your existing 2.6 to use a Starion/Conquest TBI setup might be worth investigating, since that's pretty much just swapping the intake side of things, rather than an entire engine. Install a jet valve eliminator kit while you're at it.
    Seattle, WA
    Quote Originally Posted by Pengineer1 View Post
    The stock 4G64 for the trucks has roughly ten more horsepower and very slightly less torque. With your mods to the G54b, there's probably little if any difference in HP. The smaller displacement and FI of the 4G64 should in theory yield slightly better gas mileage, but the difference may not be that great. The 4wd 5spds from 84-91+ all have the same gear ratios, but final drive ratios varied across years and models. A lower rear end ratio improves economy, but results in slower acceleration.
    Why was the bed and frame chopped off the '91? Was it in a collision? If someone cut up a serviceable vehicle, I'd be suspicious of the state of the engine or transmission. Very thorough testing seems in order before considering either for a swap.
    Found the EPA ratings:
    91 4wd w/2.4 19/22 https://afdc.energy.gov/files/pdfs/1991_feg.pdf
    86 4wd w/2.6 19/23 https://afdc.energy.gov/files/pdfs/1986_feg.pdf
    Thank you dash, fms88, and subgothius! Your responses were just what I was hoping for. Sounds like I probably ought to leave well enough alone and just remove and store the good bits for future repairs or resale. Thanks again so much!
    FMS88 (or anyone else who might care to chime in? )
    Are you saying I should be able to bolt on the manifold and fuel injection system from the 4G64 motor onto the manifold of my G54b head??? My G54b head is a remanufactured head without the jet valves, mechanical adjusted valves. It seems this would have all the advantages of my older generation motor (timing chain rather than belt) but hopefully the advantages of FI instead of carburetor????
    Again, any comments or opinions on this project are gratefully appreciated!?!?
    Now to answer your earlier question; the bed was chopped off the cab to make a trailer but you make an excellent point: very possibly the motor may have had problems or they wouldn't have chopped off the bed. I don't think that was the case because i got the cab from a buddy of mine and he knows the full history of this truck.
    Seattle, WA
    The G54b and 4G64 intake manifolds (and heads) are very different and not interchangeable. If you compare images of their respective intake gaskets (MD024628 and MD068905) you'll see what I mean.
    As dash and SubGothius mention the Starion/Conquest intake manifold will bolt onto the truck head. Both vehicles use the same head and nearly identical gaskets. However, you'll need the entire Starion intake system, engine harness, ECM, among other components to pull it off.
    Well ok, thank you. Seems it would be too expensive to find those Starion / conquest parts after this many years.
    Yeh, prolly your best bet for that would be finding a junked Starion/Conquest locally or via Car-Part.com that hasn't already had those parts harvested.
