Need more axle info, if at all possible?
What years will work?
What additional hardware/parts will I need to make the swap (Just axle parts)? Gear ratio going to be compatible (planning on 30" tires, subject to change)?
There are 3 different axles listed just for the 95', 2 do not have have ABS so I have 2 to choose from. The 2 are based on engine size, so which engine size should I be looking for?
Thank you!
