Results 1 to 8 of 8
Thread: Fuel tank
    Fuel tank
    My truck 1986 PowerRam50 needs fuel system cleaning runs too poorly to safely drive.
    We will try cleaning the existing original 18gal tank & if cannot will purchase a 15gal replacement fuel tank similar to Dorman # 576-015...
    NEED DISTANCE from tank bottom to fill hole C/L (a 15gal tank fill hole might be 1.5" lower than 18gal tank which would make my fill hose TOO SHORT) There is not enuff room to raise the tank 1.5" before it hits the bed bottom...
    Crawled under the truck this evening to take tank measurements (15"W 13"H 35"L) Dorman tank (15.25"W 11.5"H 34.12"L)
    E
    My measurements only approximate)
    The 4X4 truck 18gal tank is approx 1.5" higher x 15"W x 34"L as compared to the Dorman tank specs...
    Converts to 765 cuin larger than the 15gal tank
    765 cuin converts to 423 floz
    423 floz converts to 3 3gal
    So there is THE 3gal capacity difference but the aftermarket tank should fit as it looks the same in online photos...
    IF our 18gal tank cannot easily be cleaned will buy a 15gal galvanized aftermarket tank...
    Am in progress of rebuilding a Mikuni carb & have new OEM fuel pump ~ will pump alcohol thru both gas lines & install new in line and in tank fuel filters...
    The fuel filler tube & fuel level sending unit will need cleaning too...
    Install LOCKING GAS CAP
    Install ALARM SYSTEM
    ?Comments & Suggestions? IF someone would measure th
    eir 15gal tank (tank bottom to fill hole C/L) that would really be helpful ~ will try contacting DORMAN to see if they will provide this distance.
    Aloha ~ George
    Phoned DORMAN technical dept today & they do not know the distance (location spot) of their 15gal tank's filler tube to tank bottom.
    I' ll be doing my best to clean & reuse my original 18gal fuel tank.
    Don't wanna take a chance of the filler hose not being the right length for the small (15gal) tank.
    Beep Beep
    Oakland, CA
    1985 Dodge Power Ram 50
    Hey would you happen to know the diameter of the fuel filler hose? Are there any filler hoses for another truck that are compatible? My fuel filler hose disintegrated and I need a new one but cant find a direct fit.
    Oakland, CA
    Its the 86 4x4 model
    Nik my truck will be towed to the U.S. Marine Base Kaneohe Friday 7 March so we can begin cleaning the entire fuel system... Removing the fuel tank & fill hose needs to happen for complete cleaning of both tank & hose... I will measure the fill hose I.D.
    Car-Part.com is a good source for used parts ~ some yards will pull the part & ship it to you...
    Removed inspected cleaned reinstalled the fuel tank yesterday ~ added fresh gas & after 2 miles the truck began running normal good again ~ the fricken problem was BAD GAS..! What a PAIN..!
    Photos: http://www.mightyram50.net/vbulletin...hp?albumid=691
    BAD GAS VIDS on YouTube:
    https://youtu.be/hyBHGkr7kG4?feature=shared
    https://youtu.be/Ds4ave8HyA0?feature=shared
    https://youtu.be/xhmJmCMxMS0?feature=shared
    Quote Originally Posted by nik View Post
    2"
    Dekalb, Tx
    1986 Dodge Ram 50
    4G63
    Mu 1986 4x2 filler neck took a 2"id and I had to lube it and stretch it a bit to get it on, but it worked.
