4g64 96 eclipse swap into 4x4 Truck
Ok so about 2 years ago the 2.6 blew up in my 4x4 d50. I just found a 4g64 out of a 96-97 eclipse in a yard. I’d love to do the swap to keep the truck 4x4. I understand that the motor which is in a fwd auto eclipse is probably the narrow block. Could I theoretically use a km132 and bolt the transfer case to it and then put it all together? What flywheel and clutch combo would I need? I have access to the complete truck and eclipse. Any info is appreciated.
