I have an 86 Power Ram 50 with the 2.6L and stock Mikuni carb that has sat for years. I got the carb rebuilt and have some issues. For starters, I currently do not have an ignition lock and key cylinder, to start the truck I am sticking a key in the ignition switch itself. First problem I see is that if I open the throttle, I do not see any gas coming into the carb. When I go to start it (pouring gas into carb) it will start but die the second I return the ignition switch to the on position. As long as the starter is going it continues to run. I have all of the fuel lines run to the carb but do not see any fuel going into it, yet my mechanical fuel pump is brand new and works. I cannot tell if this is a carb issue preventing it from idling or if the ignition switch needs to be in the cylinder to idle. Regardless I have a brand new ignition switch with the cylinder on the way.
