Results 1 to 7 of 7
Thread: Idle speed control motor
    Missoula, MT
    1992 Dodge Ram 50
    Hi, I'm looking for a replacement idle speed control motor for my 92 ram 50. Specifically the one in the included picture but I either don't know what to search for or the aftermarket replacement looks way different. If anyone has replaced one of these any guidance would be greatly appreciated. Thanks Tyler
    N*Y
    damn that thing's gonna be pretty pricey brand new ..mostly u find them use with the throttle bodies...what"s wrong with ur??
    N*Y
    no that not it
    Pukwana, SD
    My 91 3.0 had a very high idle I had the ECU rebuilt that fixed the problem. Now if the AIC is bad and sticks that can fry the ECU badly making it unrepairable sometimes. Not sure what your issue is just things I’ve came across.
    Missoula, MT
    1992 Dodge Ram 50
    No that's missing a connection from the wiring harness. Unless I need to bypass it. The weird thing is for trucks and the galant they aren't internal at all. It's a sort of worm gear that hold pressure against the throttle.
    Missoula, MT
    1992 Dodge Ram 50
    The check engine came on and I'm having a bear of a time finding anyone that can read the code. So I started trouble shooting all the normal things. It's popping and puttering when I downshift and idle is a touch off. When I made my way to the idle control and took it apart the check engine went off for a couple days then kicked back on. That leads me to think there's something going out there.
