Results 1 to 5 of 5
Thread: Power steering pump need replacing?
    Washington
    1993 Mitsubishi Mighty Max
    https://youtu.be/8ca08TIcVVs
    Is this a sign the pump need replacing, or is it something else? Tensions were checked and I also took of the belts and inspected them.
    redding ca
    you sure that belt is tight? if so than the pump needs replacing. also, be sure its the right v-belt. it looks like a loose belt to me.
    Washington
    Quote Originally Posted by finalfighter View Post
    I am sure they are tight. I got replacement belts but the belts were not worn so tightened em back up. I have a new pump on order so hopefully a replacement is the fix.
    Before you replace the pump, just try out that new belt you got. Could be the old belt looks fine but is actually worn/glazed/hardened/etc. from age enough to impair its traction against the pulley.
    Washington
    Appreciate the suggestion. It turned out that although the belt was in good condition the tensioner was maxed out and the belt couldn't be tightened anymore. After trying three more shorter belts, I found the correct length and there is no more issue. I will be sending the pump back and using the money for other parts.
    Thank you!
