Sophomore
Also for clarification it was running smooth before the ICM went. Along with two of the old fusible links which I also replaced. And I went ahead and replaced the coil and resistor while I was at it. It's definitely getting fire and it's definitely getting fuel and Air. It just will not adjust where it will run when it was running just fine before.
