[QUOTE=xboxrox;85062] Remove valve cover & the fuel pump will come off[/QUOTE
... fp hits against the back of the Mikuni carb 32-35DIDTA ...
was able to 'push' it out,
by removing the valve cover, and hit the end of the fp arm, from the passenger side, over the cam,
with a long extension rod, and a hammer,
very carefully but hard, to force the fp barrel over the egr(?) valve on the carb, and the fp arm
slowly slide between the head bolt & the air jet valve ....
however, the new fp Carter M70293 can't go in, won't, can't go in, without
taking the carb out ... the fp arm won't slide between the head bolt & the air jet valve ...
the Mikuni carb has 5 bolts to attach to the manifold ...
4 hexagon head bolts are easy to locate around the double barrels opening, in a rectangle configuration, ...
where's the fifth bolt ? ... towards the front of the truck ? towards the back ?
