Results 1 to 2 of 2
Thread: Question
    Princeton NC
    Question
    Good afternoon i have a G63B i was setting the timing and i had it perfect. I installed the bottom crank bolt just to make sure truck was running smooth, and it sounded good at idle. I did not install the pulley just the crank bolt big mistake and the gear pulley came off the crank so now the engine is all out of time. Any luck i have set the timing marks back up along with removing the dist and setting it on the timing mark but no luck.
    It’s definitely out of time. Pull the valve cover and start over. Nothing was hurt but pride.
    Find me on FaceBook
