Results 1 to 25 of 140
Thread: (SOLVED) truck still wont run
    Garden Valley, CA
    i have no idea what they went to it could have been the ecu relay, im not 100% sure. and it didnt have an alarm when i got it. in some places there multiple wires that stripped and tapped to a single wire in the back of the cabs fuse box.
    Garden Valley, CA
    the Y made from the two black wires are hooked directly to the fuse box by one wire.
    If it was a clean job then it should be stock. You can always make a trip to u strip it and take plugs or a wiring harness. If taking a harness then try to do a clean strip job.
    Bit it looks and sounds like you are on the right path. Now that you have herd clicking from under the hood. If you can make it do that on a regular bases then you can find out what is clicking. Keep it up your getting close.
    Garden Valley, CA
    it could have been the ecu relay in the cab clicking. i was kinda disoriented under the dash. but i think its getting there to. i sure hope so anyway.
    WA
    To me the splices look oem. They did that on my eclipse harness the same way and electric taped it. Try to see if you can isolate the clicking to a specific relay. Did you try searching the oposite end of the burnt wire harness as well? It could be closer to the ignition then further then that into the cab.
    Make sure to tape up the exposed wires.
    Garden Valley, CA
    im getting the wring diagram of the net, i lost the other one i had.
    Stafford, VA
    Chevy V8
    way to keep on trucking man...i feel you will have this thing whooped soon enough. Goodluck bro..
    Garden Valley, CA
    thanks man, i couldnt get the diagram on my home computer. so itll have to wait till tomorrow. but im gonna test each enf othe wires that come from the igns witch.
    WA
    Happy hunting man. I don't think this would be a dealer item anymore because out trucks are obsolete. You are going to have to find a donor truck from the local scrap yard. Unless there is a cross reference to another vehicle that isnt obsolete.
