Results 1 to 3 of 3
Thread: Need help with carburetor vacuum hose locations
    Hobe Sound, Fl
    Hi all,
    I'm helping my retired neighbor get his Mighty Max running. Here are the specs: 1998 4x2 Mighty Max, 2.0 4 cylinder, Automatic with A/C.
    And the symptoms: Will only idle @ 2000rpm or more. Try and reduce the idle and it dies. Try and put it in gear when idling high, and it dies.
    Work done so far: New fuel pump, plugs, wires, etc
    I think the vacuum hoses are routed wrong. I just downloaded the diagram for the 2.6 engine from the tech section. We'll see how close they are. . . I did pop the carb apart, and it has a combo plastic float mount/needle seat with a nice crack in it. It's also way different from the rebuild kit he bought, which was worthless. The carbs in these trucks are horrible to work on. . .
    Can anyone post a few pics of their 2.0 carbed truck with all the vacuum hoses attached. Thanks!
    Hobe Sound, Fl
    I meant to say it's an 1988 truck. Can't edit after submitting I guess.
    Welcome to the site.
    There should be a hose routing picture on under the hood or on the firewall. The rebuild kit will have a crap load of parts you don't use. The float can be
    plastic or metal. It just depends on the kit. There is problem cracked vacuum lines. Check them all.
