NEW OEM MITSUBISHI FRONT HUB ASSY https://www.amayama.com/en/part/mitsubishi/mb290822
To remove the (4X4) front wheel hub a special tool (MB990954 Lock Nut Tool) is needed but is discontinued...
Supposedly a 3/4 ton GM truck tool will work by grinding off four of the six pins... I don't know if any of this is true or if the O'Reilly's part (link below) is for the correct year GM truck...
Has anyone removed their brake rotor or wheel hub using this O'Reilly's tool..? TIA
O'Reilly's sells these https://www.oreillyauto.com/detail/c/performance-tool/performance-tool-spindle-socket/pfm0/w1270/v/a/3430/automotive-truck-2000-chevrolet-k2500-pickup-4wd?q=wheel+hub+removal+tool&pos=12
