Bachelors Degree
Originally Posted by
ma3600vz
regular cab short bed
Thanks. I have a 1991 factory manual and looks like the 4G64 2.4L was only available in the regular cab. The manual trans code is V5MT1. The transfer case ratios are 1.000 (High) and 1.925 (Low). The diff ratio is 4.222. The trans ID and the final drive ratio are also stamped on a plate riveted to the firewall to the left of the valve cover.
