Results 1 to 3 of 3
Thread: 85 upper control arm umsearchable..
    tucson az
    4G61
    so im trying to piece together a complete front end rebuild for my 1st gen 86.... so I look up stuff for 85.... I cannot for the life of me find any pics... info or anything for 1st gen upper control arms..( got about 14+ hours searching so far just for info/input about these arms).. I did find a post where someone used 97-04 4wd montero fronts... but the thread died with no update... I found out the spindles from 1g and 2g MM are the same.. what is the diff between the uca? thanks for any and all input.suggestions... dont really feel like getting custom ones made at this point...
    Gray,Georgia
    1985 Dodge D-50
    Do you have your original upper control arms if so 2wd you can get the upper control arm shaft kit for $20-$30 on rock auto and same with ball joints I just rebuilt mine a year ago. Also remember on rock auto to check under the ram 50 section as well as the mitsubishi section some stuff gets listed on one but not the other.
    tucson az
    4G61
    yeah the front is all still there for now... and thanks alot I will check the shaft kit out.... didnt realize that was the upper part lol..
